[Qgis-developer] qgis server: png8 broken?
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Thu Mar 20 12:50:52 PDT 2014
Hi
Since there is now a second user describing that problem, I'm going to
revert the performance optimisation in master (I'm using it without
problem in production).
Regards,
Marco
Am 20.03.2014 20:29, schrieb Andreas Neumann:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Paolo,
> I have the same issue on Ubuntu 12.04 servers. I discussed this with
> Marco Hugentobler and he wasn't able to reproduce the issue on his
> machine. My assumption is that it may be a some sort of library issue
> and my hope is that this issue will go away once Ubuntu 14.04 is
> released with newer qt and graphic libraries.
> Here is what I found about the issue:
> - - it only happens for purely black and white and purely grayscale output
> - - if you have only the slightes bit of color you are fine. It is good
> enough to e.g. have a gray or 230,230,229 - which still looks
> identical to 230,230,230 - the issue is gone
> As a workaround you could undo the commit titled:
> Revision 8990b66eed2f00253653e64c0ceb695c08a359b7: WMS server: even
> more performant png8 conversion
> I would love to see this fixed or gone as well. It is annoying for me
> to always have to patch QGIS server after each update.
> Andreas
> Am 20.03.2014 19:07, schrieb Paolo Cavallini:
>> Hi all. If I configure une layer as png8, the server displays an
>> unreadable image: anyone confirms? qgis 2.2 on Debian wheezy. All
>> the best. _______________________________________________
>> Qgis-developer mailing list Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJTK0F7AAoJELiCsGDopvBCcqsIAJL+N8Ap3fPU31qxr1EmJIad
> vAU1cI/tmoiG5p3oVoUT7lrMhFsJLIetfNeywfcb0QX1sC0eufTbj1c0x9eHYREi
> 8FKW+Q4CLdEV4NKUXELiInJTdDvWqEDZXtrvqABjr4YWrQRNEb/BMWkZJQmsKkpe
> s0i71y7/iJjo2ZJ+Sk1Lx5tPH17PoMFqUJjbgvfRYzgtF4EfHOd2x53rmqmu6htO
> WOmBBKm4KYgp3imTaZltnhFEC0Ezy5AhqsxU6YqZOxaXQtEzy2Fa651AzlqCTnb0
> ORrA/rOFYVtKCkTDAhW+0WnlUvAkcAtA2bMsAYq9Eaw1pJEtnp8+tnjFifcXkWo=
> =H0jG
> -----END PGP SIGNATURE-----
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
