[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Matthias Kuhn matthias.kuhn at gmx.ch
Fri Mar 21 16:00:22 PDT 2014
2.2 is not that easy because it requires qt>=4.7 and rhel comes with
qt-4.6.2.
So without reverting some commits or compiling new qt packages (which
likely have additional dependencies) this won't be an option.
Instead there are now new packages (qgis-2.0.1-2) available which are
based on the latest release-2_0 patches (f802808)
I tested here in a docker container and was able to install (didn't do
any more tests actually):
docker pull centos
docker run -i -t centos /bin/bash
rpm -Uvh
http://mirror.karneval.cz/pub/linux/fedora/epel/6/x86_64/epel-release-6-8.noarch.rpm
rpm -Uvh http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
yum update
yum install qgis
Hope this helps
Matthias
On Fre 21 Mär 2014 18:19:38 CET, Olivier Dalang wrote:
> Great !! Many thanks :)
> Do you have an estimate of when you could be done ? (hours / days /
> weeks ?)
