[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Olivier Dalang olivier.dalang at gmail.com
Fri Mar 21 10:19:38 PDT 2014
Great !! Many thanks :)
Do you have an estimate of when you could be done ? (hours / days / weeks ?)
2014-03-21 18:04 GMT+01:00 Matthias Kuhn <matthias.kuhn at gmx.ch>:
> I have created the packages on the repository in use.
> I am currently trying to rebuild (Updating to 2.2 at the same time) but
> right now running into some troubles...
> I'll let you know when I succeed.
> Best
> Matthias
> On Fre 21 Mär 2014 18:01:06 CET, Alex Mandel wrote:
> > el at lists.osgeo.org
> > That's who maintains it. At this point though you might need to compile
> > it yourself.
> > Thanks,
> > Alex
> > On 03/21/2014 04:08 AM, Olivier Dalang wrote:
> >> Hi,
> >> I'm moving this discussion to the developers list.
> >> It seems the repo for QGIS on RHEL is broken. Is there any chance to
> see it
> >> fixed soon ? Do you know who's maintaining it ?
> >> Thanks !
> >> Olivier
> >> 2014-03-20 2:38 GMT+01:00 Olivier Dalang <olivier.dalang at gmail.com>:
> >>> Great that helped !
> >>> With those two commands :
> >>> rpm -Uvh
> http://mirror.centos.org/centos/6/os/x86_64/Packages/qwt-5.1.1-4.1.el6.x86_64.rpm
> >>> yum install qwt
> >>> The package resolving went further... but only to give another error :
> >>> Error Downloading Packages:
> >>>   qgis-2.0.1-1.el6.x86_64: failure: qgis-2.0.1-1.el6.x86_64.rpm from
> qgis:
> >>> [Errno 256] No more mirrors to try.
> >>> I saw your second reply afterwards, but I don't seem to find how to
> >>> activate the optional channel.
> >>> Following [1], I tried
> >>> rhn-channel --add --channel=rhel-x86_64-server-optional-6
> >>> But I get prompted for an user name/password...
> >>> One more hint ?
> >>>  [1]
> https://access.redhat.com/site/documentation/en-US/OpenShift_Enterprise/1/html/Client_Tools_Installation_Guide/Installing_Using_the_Red_Hat_Enterprise_Linux_Optional_Channel.html
> >>> 2014-03-20 2:20 GMT+01:00 Alex Mandel <tech_dev at wildintellect.com>:
> >>> On 03/19/2014 06:00 PM, Olivier Dalang wrote:
> >>>>> Dear List,
> >>>>> I'm trying to install QGIS server on Red Hat Enterprise Linux Server
> >>>>> release 6.5 (Santiago) by following the instructions provided on
> >>>> QGIS.org.
> >>>>> Unfortunately, it doesn't work so far.
> >>>>> Here's what I did :
> >>>>> 1. Add the ELGIS repository (as said here
> >>>>> http://qgis.org/en/site/forusers/alldownloads.html#qgis-1-8 ).
> >>>>> sudo rpm -Uvh
> >>>> http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
> >>>>> 2. Run these (as said here
> >>>>> http://qgis.org/en/site/forusers/alldownloads.html#id6 , only I
> removed
> >>>>> qgis-grass which I don't need )
> >>>>> sudo wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
> >>>>> sudo rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
> >>>>> sudo yum update
> >>>>> sudo yum install qgis qgis-python qgis-mapserver
> >>>>> But I get two errors and the installation does not complete :
> >>>>> Error: Package: qwtpolar-0.1.0-5.el6.x86_64 (epel)
> >>>>>            Requires: libqwt.so.5()(64bit)
> >>>>> Error: Package: qgis-2.0.1-1.el6.x86_64 (qgis)
> >>>>> Being no linux guru, I'm a bit lost about what to do... Any help
> would
> >>>> be
> >>>>> much appreciated !
> >>>>> Thanks,
> >>>>> Olivier
> >>>> My guess:
> >>>> sudo yum install qwt
> >>>> Might need to find a repo for it, I don't know what the best place to
> >>>> get it is, here's some info:
> http://pkgs.org/centos-6/centos-x86_64/qwt-5.1.1-4.1.el6.x86_64.rpm.html
> >>>> That package supplies the libqwt.so.5 library
> >>>> Enjoy,
> >>>> Alex
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140321/12b7987f/attachment-0001.html>
