[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Mar 21 10:04:18 PDT 2014
I have created the packages on the repository in use.
I am currently trying to rebuild (Updating to 2.2 at the same time) but
right now running into some troubles...
I'll let you know when I succeed.
Best
Matthias
On Fre 21 Mär 2014 18:01:06 CET, Alex Mandel wrote:
> el at lists.osgeo.org
> That's who maintains it. At this point though you might need to compile
> it yourself.
> Thanks,
> Alex
> On 03/21/2014 04:08 AM, Olivier Dalang wrote:
>> Hi,
>> I'm moving this discussion to the developers list.
>> It seems the repo for QGIS on RHEL is broken. Is there any chance to see it
>> fixed soon ? Do you know who's maintaining it ?
>> Thanks !
>> Olivier
>> 2014-03-20 2:38 GMT+01:00 Olivier Dalang <olivier.dalang at gmail.com>:
>>> Great that helped !
>>> With those two commands :
>>> rpm -Uvh
>>> http://mirror.centos.org/centos/6/os/x86_64/Packages/qwt-5.1.1-4.1.el6.x86_64.rpm
>>> yum install qwt
>>> The package resolving went further... but only to give another error :
>>> Error Downloading Packages:
>>> qgis-2.0.1-1.el6.x86_64: failure: qgis-2.0.1-1.el6.x86_64.rpm from qgis:
>>> [Errno 256] No more mirrors to try.
>>> I saw your second reply afterwards, but I don't seem to find how to
>>> activate the optional channel.
>>> Following [1], I tried
>>> rhn-channel --add --channel=rhel-x86_64-server-optional-6
>>> But I get prompted for an user name/password...
>>> One more hint ?
>>> [1]
>>> https://access.redhat.com/site/documentation/en-US/OpenShift_Enterprise/1/html/Client_Tools_Installation_Guide/Installing_Using_the_Red_Hat_Enterprise_Linux_Optional_Channel.html
>>> 2014-03-20 2:20 GMT+01:00 Alex Mandel <tech_dev at wildintellect.com>:
>>> On 03/19/2014 06:00 PM, Olivier Dalang wrote:
>>>>> Dear List,
>>>>> I'm trying to install QGIS server on Red Hat Enterprise Linux Server
>>>>> release 6.5 (Santiago) by following the instructions provided on
>>>> QGIS.org.
>>>>> Unfortunately, it doesn't work so far.
>>>>> Here's what I did :
>>>>> 1. Add the ELGIS repository (as said here
>>>>> http://qgis.org/en/site/forusers/alldownloads.html#qgis-1-8 ).
>>>>> sudo rpm -Uvh
>>>> http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
>>>>> 2. Run these (as said here
>>>>> http://qgis.org/en/site/forusers/alldownloads.html#id6 , only I removed
>>>>> qgis-grass which I don't need )
>>>>> sudo wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
>>>>> sudo rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
>>>>> sudo yum update
>>>>> sudo yum install qgis qgis-python qgis-mapserver
>>>>> But I get two errors and the installation does not complete :
>>>>> Error: Package: qwtpolar-0.1.0-5.el6.x86_64 (epel)
>>>>> Requires: libqwt.so.5()(64bit)
>>>>> Error: Package: qgis-2.0.1-1.el6.x86_64 (qgis)
>>>>> Being no linux guru, I'm a bit lost about what to do... Any help would
>>>> be
>>>>> much appreciated !
>>>>> Thanks,
>>>>> Olivier
>>>> My guess:
>>>> sudo yum install qwt
>>>> Might need to find a repo for it, I don't know what the best place to
>>>> get it is, here's some info:
>>>> http://pkgs.org/centos-6/centos-x86_64/qwt-5.1.1-4.1.el6.x86_64.rpm.html
>>>> That package supplies the libqwt.so.5 library
>>>> Enjoy,
>>>> Alex
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
