[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Alex Mandel
tech_dev at wildintellect.com
Fri Mar 21 10:01:06 PDT 2014
el at lists.osgeo.org
That's who maintains it. At this point though you might need to compile
it yourself.
Thanks,
Alex
On 03/21/2014 04:08 AM, Olivier Dalang wrote:
> Hi,
> I'm moving this discussion to the developers list.
> It seems the repo for QGIS on RHEL is broken. Is there any chance to see it
> fixed soon ? Do you know who's maintaining it ?
> Thanks !
> Olivier
> 2014-03-20 2:38 GMT+01:00 Olivier Dalang <olivier.dalang at gmail.com>:
>> Great that helped !
>> With those two commands :
>> rpm -Uvh
>> http://mirror.centos.org/centos/6/os/x86_64/Packages/qwt-5.1.1-4.1.el6.x86_64.rpm
>> yum install qwt
>> The package resolving went further... but only to give another error :
>> Error Downloading Packages:
>> qgis-2.0.1-1.el6.x86_64: failure: qgis-2.0.1-1.el6.x86_64.rpm from qgis:
>> [Errno 256] No more mirrors to try.
>> I saw your second reply afterwards, but I don't seem to find how to
>> activate the optional channel.
>> Following [1], I tried
>> rhn-channel --add --channel=rhel-x86_64-server-optional-6
>> But I get prompted for an user name/password...
>> One more hint ?
>> [1]
>> https://access.redhat.com/site/documentation/en-US/OpenShift_Enterprise/1/html/Client_Tools_Installation_Guide/Installing_Using_the_Red_Hat_Enterprise_Linux_Optional_Channel.html
>> 2014-03-20 2:20 GMT+01:00 Alex Mandel <tech_dev at wildintellect.com>:
>> On 03/19/2014 06:00 PM, Olivier Dalang wrote:
>>>> Dear List,
>>>> I'm trying to install QGIS server on Red Hat Enterprise Linux Server
>>>> release 6.5 (Santiago) by following the instructions provided on
>>> QGIS.org.
>>>> Unfortunately, it doesn't work so far.
>>>> Here's what I did :
>>>> 1. Add the ELGIS repository (as said here
>>>> http://qgis.org/en/site/forusers/alldownloads.html#qgis-1-8 ).
>>>> sudo rpm -Uvh
>>> http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
>>>> 2. Run these (as said here
>>>> http://qgis.org/en/site/forusers/alldownloads.html#id6 , only I removed
>>>> qgis-grass which I don't need )
>>>> sudo wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
>>>> sudo rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
>>>> sudo yum update
>>>> sudo yum install qgis qgis-python qgis-mapserver
>>>> But I get two errors and the installation does not complete :
>>>> Error: Package: qwtpolar-0.1.0-5.el6.x86_64 (epel)
>>>> Requires: libqwt.so.5()(64bit)
>>>> Error: Package: qgis-2.0.1-1.el6.x86_64 (qgis)
>>>> Being no linux guru, I'm a bit lost about what to do... Any help would
>>> be
>>>> much appreciated !
>>>> Thanks,
>>>> Olivier
>>> My guess:
>>> sudo yum install qwt
>>> Might need to find a repo for it, I don't know what the best place to
>>> get it is, here's some info:
>>> http://pkgs.org/centos-6/centos-x86_64/qwt-5.1.1-4.1.el6.x86_64.rpm.html
>>> That package supplies the libqwt.so.5 library
>>> Enjoy,
>>> Alex
> Qgis-developer mailing list
