[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Olivier Dalang
olivier.dalang at gmail.com
Fri Mar 21 04:08:43 PDT 2014
I'm moving this discussion to the developers list.
It seems the repo for QGIS on RHEL is broken. Is there any chance to see it
fixed soon ? Do you know who's maintaining it ?
Thanks !
Olivier
2014-03-20 2:38 GMT+01:00 Olivier Dalang <olivier.dalang at gmail.com>:
> Great that helped !
> With those two commands :
> rpm -Uvh
> http://mirror.centos.org/centos/6/os/x86_64/Packages/qwt-5.1.1-4.1.el6.x86_64.rpm
> yum install qwt
> The package resolving went further... but only to give another error :
> Error Downloading Packages:
> qgis-2.0.1-1.el6.x86_64: failure: qgis-2.0.1-1.el6.x86_64.rpm from qgis:
> [Errno 256] No more mirrors to try.
> I saw your second reply afterwards, but I don't seem to find how to
> activate the optional channel.
> Following [1], I tried
> rhn-channel --add --channel=rhel-x86_64-server-optional-6
> But I get prompted for an user name/password...
> One more hint ?
> [1]
> https://access.redhat.com/site/documentation/en-US/OpenShift_Enterprise/1/html/Client_Tools_Installation_Guide/Installing_Using_the_Red_Hat_Enterprise_Linux_Optional_Channel.html
> 2014-03-20 2:20 GMT+01:00 Alex Mandel <tech_dev at wildintellect.com>:
> On 03/19/2014 06:00 PM, Olivier Dalang wrote:
>> > Dear List,
>> > I'm trying to install QGIS server on Red Hat Enterprise Linux Server
>> > release 6.5 (Santiago) by following the instructions provided on
>> QGIS.org.
>> > Unfortunately, it doesn't work so far.
>> > Here's what I did :
>> > 1. Add the ELGIS repository (as said here
>> > http://qgis.org/en/site/forusers/alldownloads.html#qgis-1-8 ).
>> > sudo rpm -Uvh
>> http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
>> > 2. Run these (as said here
>> > http://qgis.org/en/site/forusers/alldownloads.html#id6 , only I removed
>> > qgis-grass which I don't need )
>> > sudo wget fedora.vitu.ch/EL/qgis.repo -P /etc/yum.repos.d/
>> > sudo rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
>> > sudo yum update
>> > sudo yum install qgis qgis-python qgis-mapserver
>> > But I get two errors and the installation does not complete :
>> > Error: Package: qwtpolar-0.1.0-5.el6.x86_64 (epel)
>> > Requires: libqwt.so.5()(64bit)
>> > Error: Package: qgis-2.0.1-1.el6.x86_64 (qgis)
>> > Being no linux guru, I'm a bit lost about what to do... Any help would
>> be
>> > much appreciated !
>> > Thanks,
>> > Olivier
>> My guess:
>> sudo yum install qwt
>> Might need to find a repo for it, I don't know what the best place to
>> get it is, here's some info:
>> http://pkgs.org/centos-6/centos-x86_64/qwt-5.1.1-4.1.el6.x86_64.rpm.html
>> That package supplies the libqwt.so.5 library
>> Enjoy,
>> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140321/0873c70b/attachment-0001.html>
