[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Mar 21 16:39:58 PDT 2014
Hmmm... This looks more like a problem with connecting to the repo than
a package problem.
Maybe the following helps?
yum clean all
yum update qgis
if not, are you able to communicate with the server:
ping fedora.vitu.ch
On 22.03.2014 00:34, Olivier Dalang wrote:
> Hi,
> I just tried, but still the same :
> "Error Downloading Packages:
> qgis-2.0.1-1.el6.x86_64: failure: qgis-2.0.1-1.el6.x86_64.rpm from
> qgis: [Errno 256] No more mirrors to try."
> 2014-03-22 0:00 GMT+01:00 Matthias Kuhn <matthias.kuhn at gmx.ch
> <mailto:matthias.kuhn at gmx.ch>>:
> 2.2 is not that easy because it requires qt>=4.7 and rhel comes with
> qt-4.6.2.
> So without reverting some commits or compiling new qt packages (which
> likely have additional dependencies) this won't be an option.
> Instead there are now new packages (qgis-2.0.1-2) available which are
> based on the latest release-2_0 patches (f802808)
> I tested here in a docker container and was able to install (didn't do
> any more tests actually):
> docker pull centos
> docker run -i -t centos /bin/bash
> rpm -Uvh
> http://mirror.karneval.cz/pub/linux/fedora/epel/6/x86_64/epel-release-6-8.noarch.rpm
> rpm -Uvh http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
> wget fedora.vitu.ch/EL/qgis.repo
> <http://fedora.vitu.ch/EL/qgis.repo> -P /etc/yum.repos.d/
> rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
> yum update
> yum install qgis
> Hope this helps
> Matthias
> On Fre 21 Mär 2014 18:19:38 CET, Olivier Dalang wrote:
> > Great !! Many thanks :)
> > Do you have an estimate of when you could be done ? (hours / days /
> > weeks ?)
