[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Olivier Dalang
olivier.dalang at gmail.com
Fri Mar 21 19:00:20 PDT 2014
Hah !! That did the trick !!!!
Thanks a lot !!
Olivier
2014-03-22 0:39 GMT+01:00 Matthias Kuhn <matthias.kuhn at gmx.ch>:
> Hmmm... This looks more like a problem with connecting to the repo than
> a package problem.
> Maybe the following helps?
> yum clean all
> yum update qgis
> if not, are you able to communicate with the server:
> ping fedora.vitu.ch
> On 22.03.2014 00:34, Olivier Dalang wrote:
> > Hi,
> > I just tried, but still the same :
> > "Error Downloading Packages:
> > qgis-2.0.1-1.el6.x86_64: failure: qgis-2.0.1-1.el6.x86_64.rpm from
> > qgis: [Errno 256] No more mirrors to try."
> > 2014-03-22 0:00 GMT+01:00 Matthias Kuhn <matthias.kuhn at gmx.ch
> > <mailto:matthias.kuhn at gmx.ch>>:
> > 2.2 is not that easy because it requires qt>=4.7 and rhel comes with
> > qt-4.6.2.
> > So without reverting some commits or compiling new qt packages (which
> > likely have additional dependencies) this won't be an option.
> > Instead there are now new packages (qgis-2.0.1-2) available which are
> > based on the latest release-2_0 patches (f802808)
> > I tested here in a docker container and was able to install (didn't
> do
> > any more tests actually):
> > docker pull centos
> > docker run -i -t centos /bin/bash
> > rpm -Uvh
> http://mirror.karneval.cz/pub/linux/fedora/epel/6/x86_64/epel-release-6-8.noarch.rpm
> > rpm -Uvh
> http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
> > wget fedora.vitu.ch/EL/qgis.repo
> > <http://fedora.vitu.ch/EL/qgis.repo> -P /etc/yum.repos.d/
> > rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
> > yum update
> > yum install qgis
> > Hope this helps
> > Matthias
> > On Fre 21 Mär 2014 18:19:38 CET, Olivier Dalang wrote:
> > > Great !! Many thanks :)
> > > Do you have an estimate of when you could be done ? (hours / days /
> > > weeks ?)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140322/f3257a6c/attachment.html>
