[Qgis-developer] Possible bug when turning edit mode off and on "too often"
Richard Duivenvoorde rdmailings at duif.net
Sun Mar 23 03:58:12 PDT 2014
On 23-03-14 10:37, Jakob Lanstorp wrote:
> I have also experienced extremely slow edit mode toggle on several computers
> running W7 and OSGEO4W when the QGIS project has been opened for some hours.
As you are reusing this thread, can you please also check if this also
happens if you disable all plugins too?
VPN or network related issues are for the dev pretty hard to fix,
because we cannot reproduce your setting to test.
I think the best way to be really sure that it is indeed the VPN that is
a problem, I would suggest to first check if it is maybe related to your
QGIS version/OS or computer, and see if it also happens from another
computer with a newly (that is without plugins) installed QGIS.
IF the problem still exists and is reproducable for you, then create an
issue/bug report for it, see:
http://issues.qgis.org/
Please provide as much information as possible, in your case because
devs cannot exactly mirror your system. Eg if you are on Linux, provide
the log output if you start QGIS from commandline, or on Windows provide
output via DebugView (see
http://www.qgis.org/en/site/getinvolved/development/index.html#log-output-on-windows)
Devs only have this output then to try to analyze your possible network
time-outs/connections.
HTH
Regards,
