[Qgis-developer] Problems editing WFS in QGIS
Scott Clark
sctevl at gmail.com
Mon Mar 24 06:58:31 PDT 2014
Upon further investigation it appears that WFS authentication is
broken. Further testing shows that the Add WFS dialog does not display
layers that require basic auth - even when the login is supplied. It
will only show the public layers. Note that the WMS auth works great
for me.
When you try to edit a WFS-T, I believe it is also failing to use the
supplied login info. Which results in the error I'm seeing below.
I've added the additional details to the existing bug at
http://hub.qgis.org/issues/9234
Since this makes WFS of very limited use, is this planned to be fixed in
an up-coming release? I'll happily be a tester for this!
Scott
Scott Clark wrote:
> I've been having no success using the digitizing toolbar with WFS-T.
> I'm using QGIS 2.2.0 with a GeoServer 2.4. The layers are displaying
> fine when added through the Add WFS dialog, and the editing UI is
> functional. However, on save, it fails (after freezing up QGIS for a
> minute or so) with the following message:
> Could not commit changes to layer geonode:incidentes_copeco
> Errors: ERROR: 1 feature(s) not added.
> Provider errors:
> unhandled response: html
> It's not specific to these layers and it fails on all of the layers
> I pick. I've successfully tested editing using WFS-T on this
> particular server using both our OL3 and our mobile client.
> Any ideas on workarounds or what might be going wrong?
> Thanks,
> Scott
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140324/b3b2d1a2/attachment-0001.html>
