[Qgis-developer] Problems editing WFS in QGIS
René-Luc D'Hont
rldhont at gmail.com
Mon Mar 24 11:21:43 PDT 2014
Hi Scott,
I have discovered this issue next week and I'm working on a bugfix.
I hope to propose a patch or a pull request tomorrow.
I'd like to see this fix backported.
Regards
Le 24 mars 2014 14:58, "Scott Clark" <sctevl at gmail.com> a écrit :
> Upon further investigation it appears that WFS authentication is broken.
> Further testing shows that the Add WFS dialog does not display layers that
> require basic auth - even when the login is supplied. It will only show
> the public layers. Note that the WMS auth works great for me.
> When you try to edit a WFS-T, I believe it is also failing to use the
> supplied login info. Which results in the error I'm seeing below.
> I've added the additional details to the existing bug at
> http://hub.qgis.org/issues/9234
> Since this makes WFS of very limited use, is this planned to be fixed in
> an up-coming release? I'll happily be a tester for this!
> Scott
> Scott Clark wrote:
> I've been having no success using the digitizing toolbar with WFS-T. I'm
> using QGIS 2.2.0 with a GeoServer 2.4. The layers are displaying fine
> when added through the Add WFS dialog, and the editing UI is functional.
> However, on save, it fails (after freezing up QGIS for a minute or so) with
> the following message:
> Could not commit changes to layer geonode:incidentes_copeco
> Errors: ERROR: 1 feature(s) not added.
> Provider errors:
> unhandled response: html
> It's not specific to these layers and it fails on all of the layers I
> pick. I've successfully tested editing using WFS-T on this particular
> server using both our OL3 and our mobile client.
> Any ideas on workarounds or what might be going wrong?
> Thanks,
> Scott
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140324/8bcf7c04/attachment.html>
