[Qgis-developer] Problems editing WFS in QGIS
Scott Clark
sctevl at gmail.com
Mon Mar 24 11:28:22 PDT 2014
Excellent news and many thanks!
René-Luc D'Hont wrote:
> Hi Scott,
> I have discovered this issue next week and I'm working on a bugfix.
> I hope to propose a patch or a pull request tomorrow.
> I'd like to see this fix backported.
> Regards
> Le 24 mars 2014 14:58, "Scott Clark" <sctevl at gmail.com
> <mailto:sctevl at gmail.com>> a écrit :
> Upon further investigation it appears that WFS authentication is
> broken. Further testing shows that the Add WFS dialog does not
> display layers that require basic auth - even when the login is
> supplied. It will only show the public layers. Note that the WMS
> auth works great for me.
> When you try to edit a WFS-T, I believe it is also failing to use
> the supplied login info. Which results in the error I'm seeing below.
> I've added the additional details to the existing bug at
> http://hub.qgis.org/issues/9234
> Since this makes WFS of very limited use, is this planned to be
> fixed in an up-coming release? I'll happily be a tester for this!
> Scott
> Scott Clark wrote:
>> I've been having no success using the digitizing toolbar with
>> WFS-T. I'm using QGIS 2.2.0 with a GeoServer 2.4. The layers
>> are displaying fine when added through the Add WFS dialog, and
>> the editing UI is functional. However, on save, it fails (after
>> freezing up QGIS for a minute or so) with the following message:
>> Could not commit changes to layer geonode:incidentes_copeco
>> Errors: ERROR: 1 feature(s) not added.
>> Provider errors:
>> unhandled response: html
>> It's not specific to these layers and it fails on all of the
>> layers I pick. I've successfully tested editing using WFS-T on
>> this particular server using both our OL3 and our mobile client.
>> Any ideas on workarounds or what might be going wrong?
>> Thanks,
>> Scott
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140324/b8932d9d/attachment.html>
