[Qgis-developer] Problems editing WFS in QGIS
rldhont
rldhont at gmail.com
Wed Mar 26 03:54:51 PDT 2014
Hi Scott,
I have opened a pull request
https://github.com/qgis/QGIS/pull/1266
I hope somemone can review it
Le 24/03/2014 19:28, Scott Clark a écrit :
> Excellent news and many thanks!
> René-Luc D'Hont wrote:
>> Hi Scott,
>> I have discovered this issue next week and I'm working on a bugfix.
>> I hope to propose a patch or a pull request tomorrow.
>> I'd like to see this fix backported.
>> Regards
>> Le 24 mars 2014 14:58, "Scott Clark" <sctevl at gmail.com
>> <mailto:sctevl at gmail.com>> a écrit :
>> Upon further investigation it appears that WFS authentication is
>> broken. Further testing shows that the Add WFS dialog does not
>> display layers that require basic auth - even when the login is
>> supplied. It will only show the public layers. Note that the
>> WMS auth works great for me.
>> When you try to edit a WFS-T, I believe it is also failing to use
>> the supplied login info. Which results in the error I'm seeing
>> below.
>> I've added the additional details to the existing bug at
>> http://hub.qgis.org/issues/9234
>> Since this makes WFS of very limited use, is this planned to be
>> fixed in an up-coming release? I'll happily be a tester for this!
>> Scott
>> Scott Clark wrote:
>>> I've been having no success using the digitizing toolbar with
>>> WFS-T. I'm using QGIS 2.2.0 with a GeoServer 2.4. The layers
>>> are displaying fine when added through the Add WFS dialog, and
>>> the editing UI is functional. However, on save, it fails (after
>>> freezing up QGIS for a minute or so) with the following message:
>>> Could not commit changes to layer geonode:incidentes_copeco
>>> Errors: ERROR: 1 feature(s) not added.
>>> Provider errors:
>>> unhandled response: html
>>> It's not specific to these layers and it fails on all of the
>>> layers I pick. I've successfully tested editing using WFS-T on
>>> this particular server using both our OL3 and our mobile client.
>>> Any ideas on workarounds or what might be going wrong?
>>> Thanks,
>>> Scott
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140326/6cd662b6/attachment.html>
