[Qgis-developer] Duplication of functionality: Data-defined size and Size scale field
Anita Graser
anitagraser at gmx.at
Wed Mar 26 02:06:54 PDT 2014
Am 26.03.2014, 08:26 Uhr, schrieb HAUBOURG
<regis.haubourg at eau-adour-garonne.fr>:
> +1 with Nyall,
> Labeling solution is probably the right one
+1 The labeling solution (with the small icon to the right of every
setting that can be controlled) is much better than the current
button+dialog solution in the "Style" tab.
I'll open feature requests for this.
Best wishes,
Anita
> Cordialement,
> Régis Haubourg
> Régis Haubourg
> Administrateur de données Géographiques
> Département des Systèmes d'Information (DCSI)
> Agence de l'eau Adour Garonne
> 90 rue du Férétra,
> CS 87801
> 31078 Toulouse Cedex4
> Tél: 05 61 36 82 58
> Mail: regis.haubourg at eau-adour-garonne.fr
> Assistante Malika Cherif . Tel direct : 05 61 36 36 39
> http://www.eau-adour-garonne.fr
> Accédez aux données sur l'eau : http://adour-garonne.eaufrance.fr/
>> -----Message d'origine-----
>> De : Nyall Dawson [mailto:nyall.dawson at gmail.com]
>> Envoyé : mardi 25 mars 2014 22:34
>> À : HAUBOURG
>> Cc : qgis-developer
>> Objet : Re: [Qgis-developer] Duplication of functionality: Data-defined
>> size
>> > If we do that, we need to find a more readable interface interface for
>> > data defined properties. It is unclear to the user if some options are
>> > activated in there or not. A visual flag could do the trick, or a
>> > complete gui review, to avoid another subdialog. (hierarchical view is
>> > the current ergonomy option, and I like it).
>> I think the ultimate solution would be to port the data defined gui
>> control
>> which is used in the labelling settings over to symbology.
>> Larry's done a great job with this control and it's behaves very nicely
>> - it's
>> much easier to set fields, copy expressions, temporarily deactivate
>> expressions, and see immediately if a setting is data defined.
>> I'm hoping during 2.4 to make some composer item settings data
>> definable,
>> and I plan on using this same control. It would be nice to add it to
>> symbology
>> too so that there's consistency across the entire QGIS gui.
>> Nyall
> Qgis-developer mailing list
anitagraser.com
