[Qgis-developer] Duplication of functionality: Data-defined size and Size scale field
HAUBOURG
regis.haubourg at eau-adour-garonne.fr
Wed Mar 26 00:26:37 PDT 2014
+1 with Nyall,
Labeling solution is probably the right one
Cordialement,
Régis Haubourg
Régis Haubourg
Administrateur de données Géographiques
Département des Systèmes d'Information (DCSI)
Agence de l'eau Adour Garonne
90 rue du Férétra,
CS 87801
31078 Toulouse Cedex4
Tél: 05 61 36 82 58
Mail: regis.haubourg at eau-adour-garonne.fr
Assistante Malika Cherif . Tel direct : 05 61 36 36 39
http://www.eau-adour-garonne.fr
Accédez aux données sur l'eau : http://adour-garonne.eaufrance.fr/
> -----Message d'origine-----
> De : Nyall Dawson [mailto:nyall.dawson at gmail.com]
> Envoyé : mardi 25 mars 2014 22:34
> À : HAUBOURG
> Cc : qgis-developer
> Objet : Re: [Qgis-developer] Duplication of functionality: Data-defined size
> > If we do that, we need to find a more readable interface interface for
> > data defined properties. It is unclear to the user if some options are
> > activated in there or not. A visual flag could do the trick, or a
> > complete gui review, to avoid another subdialog. (hierarchical view is
> > the current ergonomy option, and I like it).
> I think the ultimate solution would be to port the data defined gui control
> which is used in the labelling settings over to symbology.
> Larry's done a great job with this control and it's behaves very nicely - it's
> much easier to set fields, copy expressions, temporarily deactivate
> expressions, and see immediately if a setting is data defined.
> I'm hoping during 2.4 to make some composer item settings data definable,
> and I plan on using this same control. It would be nice to add it to symbology
> too so that there's consistency across the entire QGIS gui.
> Nyall
