[Qgis-developer] Qgis-Processing (former Sextante) has two bug trackers
Alexander Bruy
alexander.bruy at gmail.com
Wed Mar 26 02:31:18 PDT 2014
Hi all,
thanks to Alex, now Processing/SEXTANTE bugtracker is
a subproject of QGIS. All Processing tickets should be visible
inside main QGIS tracker, but for submitting issue one should
use Processing tracker.
Please test. If this solution will not work fine for us we can always
restore previous state.
2014-03-25 17:08 GMT+02:00 Alexander Bruy <alexander.bruy at gmail.com>:
> +1 from me to make Processing/SEXTANTE subproject if
> this keep all tickets categories and allow to see Processing
> bugs among QGIS ones
> 2014-03-24 21:32 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
>> As a sub-project, it would show up in queries of the main QGIS ticket
>> system, but at the same time be able to have it's own internal categories.
>> This to me seems the best compromise. It's really a big plugin with a
>> myriad of backends. That complexity is what makes it a little different
>> from the others mentioned. The others mentioned could be sub-projects of
>> the main QGIS too. In reality all of them are core plugins, but they are
>> still plugins. None of them are required to make QGIS work (boot). Hence
>> they each have their own category. The challenge here is
>> Processing/Sextante(I always call it by both since I do the the
>> possibility of Processing stuff that isn't sextante) needs it's own
>> categories/sub-categories.
>> Also it's really easy for use to try moving it to be a subproject and
>> then reassess (Takes about 30 seconds to move it). If it's still not
>> right then we can talk about how to move tickets.
>> Thanks,
>> Alex
>> On 03/24/2014 12:05 PM, Filipe Dias wrote:
>>> Hi
>>> I think Processing tickets should be in the main bug tracker, since GDAL
>>> tools, fTools and Grass plugin tickets are also there.
>>> Also, Qgis-Processing is a really big (and great) feature, that interests a
>>> lot of users, so it makes sense to keep its tickets in the main tracker.
>>> Regards
>>> F.
>>> On Mon, Mar 24, 2014 at 6:02 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>>>> On 03/24/2014 05:10 AM, Filipe Dias wrote:
>>>>> Hi
>>>>> QGIS-Processing (former Sextante) has open tickets on two bugtrackers:
>>>>> - the plugin bug tracker, built when it was a plugin, but with a lot of
>>>>> active tickets -> http://hub.qgis.org/projects/sextante/activity
>>>>> - the main bug tracker with a few open tickets ->
>>>>> http://hub.qgis.org/projects/quantum-gis/issues
>>>>> I understand those two can't be merged in one go, because the
>>>>> plugin-bugtracker has categories (QGIS-Processing SAGA GIS,
>>>> QGIS-Processing
>>>>> GRASS GIS etc) that don't fit in the main bug tracker. But this should be
>>>>> solved ASAP, because the current situation is quite confusing
>>>>> Regards
>>>>> F.
>>>> I'm of the opinion that the tracker should continue to be the Plugin
>>>> tracker, not the main QGIS tracker. So I'd propse moving any
>>>> Sextante/Processing tickets from the main or linking them into the
>>>> Plugin tracker.
>>>> To me it's still a plugin, just a core plugin but big enough that it's
>>>> really a subproject. If we wanted to move the Plugin tracker as a
>>>> sub-project of QGIS that would also make sense.
>>>> Also Processing bugs aside from Processing not loading aren't
>>>> showstoppers for release.
>>>> Thanks,
>>>> Alex
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
Alexander Bruy
