[Qgis-developer] Qgis-Processing (former Sextante) has two bug trackers
Filipe Dias filipesdias at gmail.com
Wed Mar 26 02:46:36 PDT 2014
Great, thanks Alex.
I see a minor issue: users who are not aware of the Processing tracker will
probably open tickets in the main tracker with the general category
Processing/Sextante and won't be able to specify which is the affected
backend (the Processing bug tracker has a subcategory for each backend:
SAGA GIS, GRASS GIS etc).
A possible workaround would be to replace the category Processing/Sextante
with Processing/SAGA GIS, Processing/R, Processing GRASS GIS etc.
Thanks
Regards
On Wed, Mar 26, 2014 at 9:31 AM, Alexander Bruy <alexander.bruy at gmail.com>wrote:
> Hi all,
> thanks to Alex, now Processing/SEXTANTE bugtracker is
> a subproject of QGIS. All Processing tickets should be visible
> inside main QGIS tracker, but for submitting issue one should
> use Processing tracker.
> Please test. If this solution will not work fine for us we can always
> restore previous state.
> 2014-03-25 17:08 GMT+02:00 Alexander Bruy <alexander.bruy at gmail.com>:
> > +1 from me to make Processing/SEXTANTE subproject if
> > this keep all tickets categories and allow to see Processing
> > bugs among QGIS ones
> > 2014-03-24 21:32 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
> >> As a sub-project, it would show up in queries of the main QGIS ticket
> >> system, but at the same time be able to have it's own internal
> categories.
> >> This to me seems the best compromise. It's really a big plugin with a
> >> myriad of backends. That complexity is what makes it a little different
> >> from the others mentioned. The others mentioned could be sub-projects of
> >> the main QGIS too. In reality all of them are core plugins, but they are
> >> still plugins. None of them are required to make QGIS work (boot). Hence
> >> they each have their own category. The challenge here is
> >> Processing/Sextante(I always call it by both since I do the the
> >> possibility of Processing stuff that isn't sextante) needs it's own
> >> categories/sub-categories.
> >> Also it's really easy for use to try moving it to be a subproject and
> >> then reassess (Takes about 30 seconds to move it). If it's still not
> >> right then we can talk about how to move tickets.
> >> Thanks,
> >> Alex
> >> On 03/24/2014 12:05 PM, Filipe Dias wrote:
> >>> Hi
> >>> I think Processing tickets should be in the main bug tracker, since
> GDAL
> >>> tools, fTools and Grass plugin tickets are also there.
> >>> Also, Qgis-Processing is a really big (and great) feature, that
> interests a
> >>> lot of users, so it makes sense to keep its tickets in the main
> tracker.
> >>> Regards
> >>> F.
> >>> On Mon, Mar 24, 2014 at 6:02 PM, Alex Mandel <
> tech_dev at wildintellect.com>wrote:
> >>>> On 03/24/2014 05:10 AM, Filipe Dias wrote:
> >>>>> Hi
> >>>>> QGIS-Processing (former Sextante) has open tickets on two
> bugtrackers:
> >>>>> - the plugin bug tracker, built when it was a plugin, but with a lot
> of
> >>>>> active tickets -> http://hub.qgis.org/projects/sextante/activity
> >>>>> - the main bug tracker with a few open tickets ->
> >>>>> http://hub.qgis.org/projects/quantum-gis/issues
> >>>>> I understand those two can't be merged in one go, because the
> >>>>> plugin-bugtracker has categories (QGIS-Processing SAGA GIS,
> >>>> QGIS-Processing
> >>>>> GRASS GIS etc) that don't fit in the main bug tracker. But this
> should be
> >>>>> solved ASAP, because the current situation is quite confusing
> >>>>> Regards
> >>>>> F.
> >>>> I'm of the opinion that the tracker should continue to be the Plugin
> >>>> tracker, not the main QGIS tracker. So I'd propse moving any
> >>>> Sextante/Processing tickets from the main or linking them into the
> >>>> Plugin tracker.
> >>>> To me it's still a plugin, just a core plugin but big enough that it's
> >>>> really a subproject. If we wanted to move the Plugin tracker as a
> >>>> sub-project of QGIS that would also make sense.
> >>>> Also Processing bugs aside from Processing not loading aren't
> >>>> showstoppers for release.
> >>>> Thanks,
> >>>> Alex
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Alexander Bruy
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140326/de6c5242/attachment-0001.html>
