[Qgis-developer] Fwd: [QGIS Application - Bug #6948] (Closed) Dxf to Shape plugin doesn't work any more
Paolo Cavallini cavallini at faunalia.it
Thu Mar 27 01:16:03 PDT 2014
BTW, what about removing the obsolete plugin before 2.4?
All the best.
-------- Messaggio originale --------
Oggetto: 	[QGIS Application - Bug #6948] (Closed) Dxf to Shape plugin
Data: 	Wed, 26 Mar 2014 17:52:29 -0700
Mittente: 	redmine at qgis.org
A: 	undisclosed-recipients:;
Issue #6948 has been updated by Nathan Woodrow.
  * Status changed from Feedback to Closed
  * Resolution set to wontfix
This is no longer supported. Project -> Export DXF is the new method.
  Bug #6948: Dxf to Shape plugin doesn't work any more
  <http://hub.qgis.org/issues/6948>
  * Author: Alessandro Ciali
  * Status: Closed
  * Priority: Normal
  * Assigned to:
  * Category:
  * Target version:
  * Platform:
  * Platform version:
  * Status info:
  * Resolution: wontfix
  * Patch supplied: No
  * Affected version: master
  * Causes crash or corruption: No
  * Tag:
1.Open tool
2.find a dxf (I tried with a 2004 version dxf that was properly
converted some time ago)
3. give an output shape
4. select an option (tried every option)
The tool window closes without error but nothing appens
Esperienced On w7 64bit with latest version updated by OSGeo4W; affectet
version1.8 too
You have received this notification because you have either subscribed
to it, or are involved in it.
To change your notification preferences, please click here:
http://hub.qgis.org/my/account
