[Qgis-developer] Fwd: [QGIS Application - Bug #6948] (Closed) Dxf to Shape plugin doesn't work any more
Andreas Neumann
a.neumann at carto.net
Thu Mar 27 01:34:41 PDT 2014
Project -> Export DXF is only for exporting DXF, while dxf to shp is
about importing.
The import of QGIS through OGR is still unsatisfactory. I would still
keep this plugin around.
It seems to still work in master.
The bug mentioned is probably because the user used a format version
that is too new. Also OGR would not be able to load such a file.
Andreas
Am 27.03.2014 08:16, schrieb Paolo Cavallini:
> BTW, what about removing the obsolete plugin before 2.4?
> All the best.
> -------- Messaggio originale --------
> Oggetto: [QGIS Application - Bug #6948] (Closed) Dxf to Shape plugin
> Data: Wed, 26 Mar 2014 17:52:29 -0700
> Mittente: redmine at qgis.org
> A: undisclosed-recipients:;
> Issue #6948 has been updated by Nathan Woodrow.
> * Status changed from Feedback to Closed
> * Resolution set to wontfix
> This is no longer supported. Project -> Export DXF is the new method.
> Bug #6948: Dxf to Shape plugin doesn't work any more
> <http://hub.qgis.org/issues/6948>
> * Author: Alessandro Ciali
> * Status: Closed
> * Priority: Normal
> * Assigned to:
> * Category:
> * Target version:
> * Platform:
> * Platform version:
> * Status info:
> * Resolution: wontfix
> * Patch supplied: No
> * Affected version: master
> * Causes crash or corruption: No
> * Tag:
> 1.Open tool
> 2.find a dxf (I tried with a 2004 version dxf that was properly
> converted some time ago)
> 3. give an output shape
> 4. select an option (tried every option)
> The tool window closes without error but nothing appens
> Esperienced On w7 64bit with latest version updated by OSGeo4W; affectet
> version1.8 too
> You have received this notification because you have either subscribed
> to it, or are involved in it.
> To change your notification preferences, please click here:
> http://hub.qgis.org/my/account
> Qgis-developer mailing list
