[Qgis-developer] error starting qgis (built from source)
Daniel Scholten
scholten at riseup.net
Mon May 5 06:57:06 PDT 2014
On 05/03/2014 09:46 AM, Yves Jacolin wrote:
> Le samedi 3 mai 2014, 08:47:30 Nyall Dawson a écrit :
>>> Maybe you need to update your LD_LIBRARY_PATH so QGIS or Qt knows of the
>>> custom OCI lib path during runtime?
>> Possibly running "sudo ldconfig" may help?
>> Nyall
> probably not without adding a new file in /etc/ld.so.conf.d/ for example
> qgis.conf containing: /usr/local/lib/
> So yes after that update your lib PATH with sudo ldconfig.
> Y.
I've had the same problem and the above worked for me. Except that now I
found that some plugin libraries are missing. During start of QGIS I get
a message "Unable to load GdalTools plugin. The required "osgeo
[python-gdal]" module is missing." and after a Python error "Couldn't
load plugin 'processing' [...]". After QGIS startup in the plugin
manager with GdalTools everything seems to be ok, whereas processing
plugin is marked broken and the reinstall button is disabled. Any
suggestions what to do? Daniel
