[Qgis-developer] error starting qgis (built from source)
chris marx chrismarx at gmail.com
Mon May 5 07:10:22 PDT 2014
Hi Daniel,
 I still haven't got my install working, any steps in particular that have
been suggested that you found make it work for you?
Chris-
On Mon, May 5, 2014 at 9:57 AM, Daniel Scholten <scholten at riseup.net> wrote:
> On 05/03/2014 09:46 AM, Yves Jacolin wrote:
> > Le samedi 3 mai 2014, 08:47:30 Nyall Dawson a écrit :
> >>> Maybe you need to update your LD_LIBRARY_PATH so QGIS or Qt knows of
> the
> >>> custom OCI lib path during runtime?
> >> Possibly running "sudo ldconfig" may help?
> >> Nyall
> > probably not without adding a new file in /etc/ld.so.conf.d/ for example
> > qgis.conf containing: /usr/local/lib/
> > So yes after that update your lib PATH with sudo ldconfig.
> > Y.
> I've had the same problem and the above worked for me. Except that now I
> found that some plugin libraries are missing. During start of QGIS I get
> a message "Unable to load GdalTools plugin. The required "osgeo
> [python-gdal]" module is missing." and after a Python error "Couldn't
> load plugin 'processing' [...]". After QGIS startup in the plugin
> manager with GdalTools everything seems to be ok, whereas processing
> plugin is marked broken and the reinstall button is disabled. Any
> suggestions what to do? Daniel
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140505/6cb850e6/attachment-0001.html>
