[Qgis-developer] error starting qgis (built from source)
Yves Jacolin yjacolin at free.fr
Mon May 5 09:46:20 PDT 2014
Le lundi 5 mai 2014, 15:57:06 Daniel Scholten a écrit :
> I've had the same problem and the above worked for me. Except that now I
> found that some plugin libraries are missing. During start of QGIS I get
> a message "Unable to load GdalTools plugin. The required "osgeo
> [python-gdal]" module is missing." and after a Python error "Couldn't
> load plugin 'processing' [...]". After QGIS startup in the plugin
> manager with GdalTools everything seems to be ok, whereas processing
> plugin is marked broken and the reinstall button is disabled. Any
> suggestions what to do? Daniel
sudo apt-get install python3-pyqt4.qsci made the process plugin working for
me.
For Gdal plugin, I built GDAL with Python Binding but I guess you should
install python3-gdal
Y.
> Qgis-developer mailing list
Yves Jacolin
