[Qgis-developer] error starting qgis (built from source)
Larry Shaffer larrys at dakotacarto.com
Mon May 5 10:16:47 PDT 2014
On Mon, May 5, 2014 at 10:46 AM, Yves Jacolin <yjacolin at free.fr> wrote:
> Le lundi 5 mai 2014, 15:57:06 Daniel Scholten a écrit :
> > I've had the same problem and the above worked for me. Except that now I
> > found that some plugin libraries are missing. During start of QGIS I get
> > a message "Unable to load GdalTools plugin. The required "osgeo
> > [python-gdal]" module is missing." and after a Python error "Couldn't
> > load plugin 'processing' [...]". After QGIS startup in the plugin
> > manager with GdalTools everything seems to be ok, whereas processing
> > plugin is marked broken and the reinstall button is disabled. Any
> > suggestions what to do? Daniel
> sudo apt-get install python3-pyqt4.qsci made the process plugin working for
> me.
> For Gdal plugin, I built GDAL with Python Binding but I guess you should
> install python3-gdal
Python 3 is not supported by QGIS. Install the Python 2 support packages.
Required third-party Python packages include psycopg2, matplotlib,
pyparsing and qscintilla2 for QGIS at runtime; and, numpy for GDAL (raster
support, I believe).
Regards,
Larry
> Y.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Yves Jacolin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140505/54d37591/attachment.html>
