[Qgis-developer] error starting qgis (built from source)
Daniel Scholten scholten at riseup.net
Tue May 6 03:59:19 PDT 2014
On 05/05/2014 07:16 PM, Larry Shaffer wrote:
> Hi,
> On Mon, May 5, 2014 at 10:46 AM, Yves Jacolin <yjacolin at free.fr
> <mailto:yjacolin at free.fr>> wrote:
>     Le lundi 5 mai 2014, 15:57:06 Daniel Scholten a écrit :
>     > I've had the same problem and the above worked for me. Except that
>     now I
>     > found that some plugin libraries are missing. During start of QGIS
>     I get
>     > a message "Unable to load GdalTools plugin. The required "osgeo
>     > [python-gdal]" module is missing." and after a Python error "Couldn't
>     > load plugin 'processing' [...]". After QGIS startup in the plugin
>     > manager with GdalTools everything seems to be ok, whereas processing
>     > plugin is marked broken and the reinstall button is disabled. Any
>     > suggestions what to do? Daniel
>     sudo apt-get install python3-pyqt4.qsci made the process plugin
>     working for
>     me.
>     For Gdal plugin, I built GDAL with Python Binding but I guess you should
>     install python3-gdal
> Python 3 is not supported by QGIS. Install the Python 2 support packages.
> Required third-party Python packages include psycopg2, matplotlib,
> pyparsing and qscintilla2 for QGIS at runtime; and, numpy for GDAL
> (raster support, I believe).
I first installed psycopg2, matplotlib, pyparsing, qscintilla2
and numpy, which did not solve the problem. Then I installed
python3-pyqt4.qsci, which also didn't solve it. Any further ideas? Daniel
