[Qgis-developer] Is there an advantage in using pyuic on command line instead of uic.loadUi in plugin source?
Nathan Woodrow madmanwoo at gmail.com
Mon May 5 23:54:52 PDT 2014
I normally do it this way:
base, widget = uic.loadUiType('myui.ui')
class MyWidget(base, widget):
    def __init__(self, parent=None)
         super(MyWidget, self).__init__(parent)
- Nathan
On Tue, May 6, 2014 at 4:52 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Sat, Apr 26, 2014 at 2:45 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> Hi,
>> I'm wondering if there is an advantage in using pyuic to manually compile
>> .ui files instead of just using uic.loadUi() in the plugin directly, e.g.
>> from PyQt4 import uic
>> self.dock = uic.loadUi( os.path.join( path, "dockwidget2.ui" ) )
> As Martin mentioned, getting the class type back is nicer. I tested this
> and it works nicely:
> import os
> from PyQt4 import QtCore, QtGui, uic
> BASE_CLASS = uic.loadUiType(os.path.join(
>     os.path.dirname(__file__), 'results_dialog_base.ui'))[0]
> class ResultDialog(QtGui.QDialog, BASE_CLASS):
>     """Dialog for showing the results of the plugin creation process."""
>     def __init__(self):
>         QtGui.QDialog.__init__(self)
>         # Set up the user interface from Designer.
>         self.setupUi(self)
> The advantage is that you can use Qt multi-inheritance which means less
> and cleaner code. More details in the Qt section at [1].
> [1] http://test.inasafe.org/en/developer-docs/coding_standards.html
> Regards
> Tim
>> Thanks for any insights!
>> Best wishes,
>> Anita
>> anitagraser.com
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140506/3a3c90d7/attachment.html>
