[Qgis-developer] Is there an advantage in using pyuic on command line instead of uic.loadUi in plugin source?
Tim Sutton
lists at linfiniti.com
Tue May 6 00:01:31 PDT 2014
Hi
On Tue, May 6, 2014 at 8:54 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> I normally do it this way:
> base, widget = uic.loadUiType('myui.ui')
> class MyWidget(base, widget):
> def __init__(self, parent=None)
> super(MyWidget, self).__init__(parent)
According to the docs[1] you get the concrete class first, then the base
class in the returned tuple:
PyQt4.uic.loadUiType(*uifile*[, *from_imports=False*[,
*resource_suffix='_rc'*]])<http://pyqt.sourceforge.net/Docs/PyQt4/designer.html#PyQt4.uic.loadUiType>
Load a Qt Designer .ui file and return a tuple of the generated *form
class* and
the *Qt base class*. These can then be used to create any number of
instances of the user interface without having to parse the .ui file more
than once.
[1] http://pyqt.sourceforge.net/Docs/PyQt4/designer.html#the-uic-module
Regards
Tim
> - Nathan
> On Tue, May 6, 2014 at 4:52 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Sat, Apr 26, 2014 at 2:45 PM, Anita Graser <anitagraser at gmx.at> wrote:
>>> Hi,
>>> I'm wondering if there is an advantage in using pyuic to manually
>>> compile .ui files instead of just using uic.loadUi() in the plugin
>>> directly, e.g.
>>> from PyQt4 import uic
>>> self.dock = uic.loadUi( os.path.join( path, "dockwidget2.ui" ) )
>> As Martin mentioned, getting the class type back is nicer. I tested this
>> and it works nicely:
>> import os
>> from PyQt4 import QtCore, QtGui, uic
>> BASE_CLASS = uic.loadUiType(os.path.join(
>> os.path.dirname(__file__), 'results_dialog_base.ui'))[0]
>> class ResultDialog(QtGui.QDialog, BASE_CLASS):
>> """Dialog for showing the results of the plugin creation process."""
>> def __init__(self):
>> QtGui.QDialog.__init__(self)
>> # Set up the user interface from Designer.
>> self.setupUi(self)
>> The advantage is that you can use Qt multi-inheritance which means less
>> and cleaner code. More details in the Qt section at [1].
>> [1] http://test.inasafe.org/en/developer-docs/coding_standards.html
>> Regards
>> Tim
>>> Thanks for any insights!
>>> Best wishes,
>>> Anita
>>> anitagraser.com
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140506/ec754ca1/attachment.html>
