[Qgis-developer] Is there an advantage in using pyuic on command line instead of uic.loadUi in plugin source?
Tim Sutton lists at linfiniti.com
Tue May 6 00:04:32 PDT 2014
Hi
On Tue, May 6, 2014 at 9:01 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Tue, May 6, 2014 at 8:54 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> I normally do it this way:
>> base, widget = uic.loadUiType('myui.ui')
>> class MyWidget(base, widget):
>>     def __init__(self, parent=None)
>>          super(MyWidget, self).__init__(parent)
> According to the docs[1] you get the concrete class first, then the base
> class in the returned tuple:
> PyQt4.uic.loadUiType(*uifile*[, *from_imports=False*[,
> *resource_suffix='_rc'*]])<http://pyqt.sourceforge.net/Docs/PyQt4/designer.html#PyQt4.uic.loadUiType>
> Load a Qt Designer .ui file and return a tuple of the generated *form
> class* and the *Qt base class*. These can then be used to create any
> number of instances of the user interface without having to parse the .ui file
> more than once.
> [1] http://pyqt.sourceforge.net/Docs/PyQt4/designer.html#the-uic-module
> Regards
Ah did you mean that you save a line of code by using super?
Regards
Tim
> Tim
>> - Nathan
>> On Tue, May 6, 2014 at 4:52 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>> Hi
>>> On Sat, Apr 26, 2014 at 2:45 PM, Anita Graser <anitagraser at gmx.at>wrote:
>>>> Hi,
>>>> I'm wondering if there is an advantage in using pyuic to manually
>>>> compile .ui files instead of just using uic.loadUi() in the plugin
>>>> directly, e.g.
>>>> from PyQt4 import uic
>>>> self.dock = uic.loadUi( os.path.join( path, "dockwidget2.ui" ) )
>>> As Martin mentioned, getting the class type back is nicer. I tested this
>>> and it works nicely:
>>> import os
>>> from PyQt4 import QtCore, QtGui, uic
>>> BASE_CLASS = uic.loadUiType(os.path.join(
>>>     os.path.dirname(__file__), 'results_dialog_base.ui'))[0]
>>> class ResultDialog(QtGui.QDialog, BASE_CLASS):
>>>     """Dialog for showing the results of the plugin creation process."""
>>>     def __init__(self):
>>>         QtGui.QDialog.__init__(self)
>>>         # Set up the user interface from Designer.
>>>         self.setupUi(self)
>>> The advantage is that you can use Qt multi-inheritance which means less
>>> and cleaner code. More details in the Qt section at [1].
>>> [1] http://test.inasafe.org/en/developer-docs/coding_standards.html
>>> Regards
>>> Tim
>>>> Thanks for any insights!
>>>> Best wishes,
>>>> Anita
>>>> anitagraser.com
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Tim Sutton - QGIS Project Steering Committee Member
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140506/12a2261c/attachment-0001.html>
