[Qgis-developer] MetaSearch core integration questions
Tom Kralidis
tomkralidis at gmail.com
Mon May 12 16:54:31 PDT 2014
Hi all: FYI MetaSearch [0] has been approved for inclusion in QGIS
core [1] [2]. I've started to work on the integration. I originally
envisioned an automagic process using git merge/read-tree, however
given the issues below, I am finally realizing that a canned release
brute force dump might be the best thing as a first step.
My plan is to create a build process which exports a stable MetaSearch
for QGIS release.
The following issues exist:
- handling dependencies: MetaSearch requires OWSLib, pygments, and
Jinja2 [3] (and everything upstream of them that is not in the Python
standard library) and integrates these via pip. For publishing to
plugins.qgis.org we bundle them into the .zip package into a dir call
ext-libs. We can do the same for QGIS inclusion for now. What is the
state of affairs in terms of QGIS build workflow / core support for
Python dependencies? This would really move forward the Python plugin
(core Python plugins or installed via plugins.qgis.org) ecosystem
knowing that a few core Python libs are in core
- cmake: MetaSearch does build type things via Paver. I've added
various CMakeLists.txt files in the code (not pushed yet), however if
I include the dependencies (see point above), does this mean I need to
add CMakeLists.txt files across the dependency directory structure
(for example, see current MetaSearch download at [4])?!
I hope the above is somewhat clear. Admittedly I am new to the QGIS
build story and have only used cmake in my MapServer dev. Thanks for
the help so far in irc.
..Tom
[0] https://github.com/geopython/MetaSearch
[1] http://lists.osgeo.org/pipermail/qgis-psc/2014-May/002155.html
[2] http://lists.osgeo.org/pipermail/qgis-psc/2014-May/002166.html
[3] https://github.com/geopython/MetaSearch/blob/master/requirements.txt
[4] http://plugins.qgis.org/plugins/MetaSearch/version/0.2.0
