[Qgis-developer] Users Manual Form annotations challenge
Alexandre Neto
senhor.neto at gmail.com
Mon May 19 01:12:50 PDT 2014
The workaround proposed in the bug report did not work. And I have now
realized that the screenshot DOES depend of the platform. I will have to
keep the windows screenshot for now.
Thank you all for your help.
Alexandre
On Fri, May 16, 2014 at 11:55 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> Hello all,
> It seems to be the same problem. I will look into the bug report and test
> it as soon as I.
> Happily this screenshot does not depends of the platform. So I can create
> it in other SO.
> Thanks.
> Alexandre
> On Fri, May 16, 2014 at 9:28 PM, J. Gustavo Rocha <jgr at di.uminho.pt>wrote:
>> Hi all, olá Alexandre,
>> Probably you found the bug that Matthias mentioned, which is still
>> opened. On my QGIS 2.2, on Ubuntu 12.04 your example crashes QGIS.
>> But writing a few lines of python, your form loads. So, it might (I
>> really don't know!) be a QGIS problem, although it works fine on other
>> platforms.
>> Opening your form with just vanilla python+qt:
>> import sys
>> from PyQt4 import QtCore, QtGui, uic
>> form_class = uic.loadUiType("annotations_form.ui")[0]
>> class MyWindowClass(QtGui.QMainWindow, form_class):
>> def __init__(self, parent=None):
>> QtGui.QMainWindow.__init__(self, parent)
>> self.setupUi(self)
>> app = QtGui.QApplication(sys.argv)
>> myWindow = MyWindowClass(None)
>> myWindow.show()
>> app.exec_()
>> The form opens: https://dl.dropboxusercontent.
>> com/u/5489125/Dialog_013.png
>> I hate to say, but for now, it is better to prepare the documentation and
>> screen captures on another platform :-(
>> Regards,
>> J. Gustavo
>> Em 16-05-2014 20:03, Matthias Kuhn escreveu:
>> Hi Alexandre,
>>> are you by any chance encountering this bug?
>>> http://hub.qgis.org/issues/8760
>>> -- Matthias
>>> On 13.05.2014 00:29, Alexandre Neto wrote:
>>>> I'm trying to update the Users Manual Screenshot for form annotations.
>>>> In my case, QGIS is crashing when I try to use a form. Can anyone
>>>> please check if it's working or if there is something wrong with my
>>>> form [0]?
>>>> Also, there is a broken link [1] in the Users Manual in this section
>>>> that would explain how to crate a form to use with form annotation.
>>>> Can we ressuscitate the link? I used Tim Sutton video to create my form.
>>>> Thanks!
>>>> Alexandre Neto
>>>> [2] https://www.dropbox.com/s/4a3mqni2becruh9/annotations_form.ui
>>>> [1] http://blog.qgis.org/node/143
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> J. Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Informática
>> Universidade do Minho
>> 4710-057 Braga
>> Tel: +351 253604480
>> Fax: +351 253604471
>> Móvel: +351 910333888
>> skype: nabocudnosor
>> "I would love to change the world, but they won't give me the source
>> code" -- Unknown Geek
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140519/ef7f3d9f/attachment.html>
