[Qgis-developer] Users Manual Form annotations challenge
Alexandre Neto
senhor.neto at gmail.com
Fri May 16 15:55:38 PDT 2014
Hello all,
It seems to be the same problem. I will look into the bug report and test
it as soon as I.
Happily this screenshot does not depends of the platform. So I can create
it in other SO.
Thanks.
Alexandre
On Fri, May 16, 2014 at 9:28 PM, J. Gustavo Rocha <jgr at di.uminho.pt> wrote:
> Hi all, olá Alexandre,
> Probably you found the bug that Matthias mentioned, which is still opened.
> On my QGIS 2.2, on Ubuntu 12.04 your example crashes QGIS.
> But writing a few lines of python, your form loads. So, it might (I really
> don't know!) be a QGIS problem, although it works fine on other platforms.
> Opening your form with just vanilla python+qt:
> import sys
> from PyQt4 import QtCore, QtGui, uic
> form_class = uic.loadUiType("annotations_form.ui")[0]
> class MyWindowClass(QtGui.QMainWindow, form_class):
> def __init__(self, parent=None):
> QtGui.QMainWindow.__init__(self, parent)
> self.setupUi(self)
> app = QtGui.QApplication(sys.argv)
> myWindow = MyWindowClass(None)
> myWindow.show()
> app.exec_()
> The form opens: https://dl.dropboxusercontent.com/u/5489125/Dialog_013.png
> I hate to say, but for now, it is better to prepare the documentation and
> screen captures on another platform :-(
> Regards,
> J. Gustavo
> Em 16-05-2014 20:03, Matthias Kuhn escreveu:
> Hi Alexandre,
>> are you by any chance encountering this bug?
>> http://hub.qgis.org/issues/8760
>> -- Matthias
>> On 13.05.2014 00:29, Alexandre Neto wrote:
>>> I'm trying to update the Users Manual Screenshot for form annotations.
>>> In my case, QGIS is crashing when I try to use a form. Can anyone
>>> please check if it's working or if there is something wrong with my
>>> form [0]?
>>> Also, there is a broken link [1] in the Users Manual in this section
>>> that would explain how to crate a form to use with form annotation.
>>> Can we ressuscitate the link? I used Tim Sutton video to create my form.
>>> Thanks!
>>> Alexandre Neto
>>> [2] https://www.dropbox.com/s/4a3mqni2becruh9/annotations_form.ui
>>> [1] http://blog.qgis.org/node/143
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
> "I would love to change the world, but they won't give me the source code"
> -- Unknown Geek
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140516/7dd980ff/attachment.html>
