[Qgis-developer] Geospackage Slow in QGIS
Jeremy Palmer
JPalmer at linz.govt.nz
Sat May 17 01:29:22 PDT 2014
HI Stefan,
Call from QGIS is here: https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrfeatureiterator.cpp#L45
GDAL code is here:
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/gpkg/ogrgeopackagedatasource.cpp#L421
My profiler says all the time is in OGRGeoPackageDataSource::Open.
Also a simple check via the command line for the given database:
qlite3 test_parcels.gpkg
sqlite> .timer ON
sqlite> PRAGMA integrity_check;
ok
CPU Time: user 3.384211 sys 0.756047
Cheers,
Jeremy
________________________________________
Sent: Saturday, 17 May 2014 8:20 p.m.
To: Jeremy Palmer
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Geospackage Slow in QGIS
Hi Jeremy
Is this PRAGMA integrity_check really the bottle neck?
Is it an integrity check on a data type (e.g. integer - its probably actually an integrity check on SRID)?
Can you point to the code?
Yours, Stefan
2014-05-17 9:32 GMT+02:00 Jeremy Palmer <JPalmer at linz.govt.nz<mailto:JPalmer at linz.govt.nz>>:
I've just been using the new implementation of Geopackage in QGIS :) However each map render or feature info is very slow for large database files - even with the new GDAL/OGR Geopackage spatial index support. Each time QGIS renders a new map view or executes a feature info it re-opens the Geopackage file in QgsOgrFeatureIterator via OGROpen, and the Geopackage driver open method runs PRAGMA integrity_check which is very slow (4 secs with my 2GB test file). This integrity check is actually a Geopackage requirement.
How can this be fixed? At the in QGIS or GDAL/OGR level?
Cheers,
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz<mailto:info at linz.govt.nz>) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
