[Qgis-developer] Legend refactoring branch merged
Larry Shaffer larrys at dakotacarto.com
Thu May 22 08:57:04 PDT 2014
Hi Martin,
Thanks for the quick fixes. All of my reported issues were addressed. The
reported funky connection issue appears to be my mistake. I believe I must
have had a layer still in edit mode somewhere in the legend when I thought
there was none. Could not reproduce that issue.
However, I did notice that the new legend is not quite the same as the old.
You can now edit the name of the layer directly with a click-hover. Very
nice!
Geez, all that work and only one small new feature? :-)
Thanks again for upgrading the previous legend's tangled and limiting code.
Looking forward to the new features and usability this will bring.
Regards,
Larry
On Thu, May 22, 2014 at 12:42 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Larry
> On Thu, May 22, 2014 at 2:39 AM, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
> > Hi Martin,
> > Thanks for your work on this and for the sponsors that supported it!
> > Couples things I noticed:
> > * There is no longer and indication that a layer is in edit mode, or not,
> > i.e. the edit pencil icon, and its relative states (red or yellow), is
> gone.
> > * There is no longer an indication of the active layer, previously the
> one
> > underlined. This is different than the currently selected layer(s). The
> > underline would persist with no selection, or multiple selections, and
> would
> > mirror the view's currentItem(), or in maybe now currentIndex(). When
> > iface.activeLayer() is used in console, it should return the identical
> layer
> > in the legend that is underlined, or otherwise indicated as active.
> > * Something is funky with the connections between the legend and the
> Current
> > Edits functionality. After a layer is no layers are editable anymore, the
> > submenu is still active, offering to cancel edits. I added that code, and
> > can investigate more after the feature freeze.
> > * There is no longer a tool tip when hovering over the layer, showing the
> > layer's source definition.
> Thanks a lot for the feedback. Will address that shortly.
> > * When opening one project, QGIS crashed with the following (project
> never
> > loads):
> > Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
> > Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000010
> > 0   org.qgis.qgis2_core  QgsSymbolV2::drawPreviewIcon(QPainter*, QSize)
> + 42
> > (qlist.h:99)
> > 1   org.qgis.qgis2_core
> > QgsSymbolLayerV2Utils::symbolPreviewPixmap(QgsSymbolV2*, QSize) + 114
> > (qgssymbollayerv2utils.cpp:517)
> > 2   org.qgis.qgis2_gui
> > QgsLayerTreeModel::addSymbologyToVectorLayer(QgsLayerTreeLayer*) + 570
> > (qgslayertreemodel.cpp:520)
> > 3   org.qgis.qgis2_gui
> > QgsLayerTreeModel::addSymbologyToLayer(QgsLayerTreeLayer*) + 88
> > (qgslayertreemodel.cpp:480)
> > 4   QtCore                      QMetaObject::activate(QObject*,
> QMetaObject
> > const*, int, void**) + 2141
> > 5   org.qgis.qgis2_core
> > QgsLayerTreeLayer::registryLayersAdded(QList<QgsMapLayer*>) + 307
> > (qgslayertreelayer.cpp:145)
> > 6   org.qgis.qgis2_core  QgsLayerTreeLayer::qt_static_metacall(QObject*,
> > QMetaObject::Call, int, void**) + 172 (qlist.h:731)
> Oh, sorry about that. Something must have gone wrong with a vector
> layer's symbol. I can't see where the problem could be straight away -
> would it be possible for you to send me the project file - or see if
> you can provide more information how to replicate the problem?
> Regards
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140522/a61137c0/attachment-0001.html>
