[Qgis-developer] Not working mac nightly
Larry Shaffer
larrys at dakotacarto.com
Wed May 28 17:52:52 PDT 2014
The Mac QGIS nightly site has been updated:
http://qgis.dakotacarto.com/
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Wed, May 28, 2014 at 5:12 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Vincent,
> Under a normal compiling of QGIS, the psycopg2 Python package is not
> installed, and is required to be installed by the user/developer. This is
> different than the stable QGIS installer bundles from Kyngchaos.com, which
> have other supporting libs and Python packages bundled in. Likewise, there
> are no extra supporting installs for the Processing plugin, e.g. GRASS,
> OTB, etc..
> Adding all the supporting libs/packages would make the nightly
> upload/download much, much larger. Also, the nightly is meant to be basic
> build output for compiling and bundling, as defined by the CMake variable:
> QGIS_MACAPP_BUNDLE=2
> If the supporting libs/packages are included in those CMake scripts [1],
> then they are in the nightly, excepting instances where there are issues
> building them or building against them with the latest master version.
> I will add information to the nightly download website that indicates what
> extras components need locally installed.
> Kyngchaos.com has many of the required Python packages available as
> installers [2].
> [0] https://github.com/qgis/QGIS/blob/master/INSTALL#L1989-L1992
> [1] https://github.com/qgis/QGIS/tree/master/mac/cmake
> [2] http://www.kyngchaos.com/software/python
> Regards,
> Larry Shaffer
> Dakota Cartography
> On Sun, May 25, 2014 at 2:07 AM, Vincent TINET <v.tinet at agam.org> wrote:
>> It is loading fine with Larry’s new version.
>> Except that the psycopg2 python library is missing from the bundle.
>> Processing (at least) is needing it to load.
>> Le 24 mai 2014 à 14:10, Vincent TINET <v.tinet at agam.org> a écrit :
>> > I tried to test the nightly builds a few days in a row and it doesn’t
>> starts with the following error :
>> > Process: QGIS_2.3-dev [3186]
>> > Path:
>> /Volumes/VOLUME/QGIS_2.3-dev.app/Contents/MacOS/QGIS_2.3-dev
>> > Identifier: org.qgis.qgis-dev
>> > Version: ???
>> > Code Type: X86-64 (Native)
>> > Parent Process: launchd [137]
>> > Responsible: QGIS_2.3-dev [3186]
>> > User ID: 501
>> > Date/Time: 2014-05-24 14:08:16.406 +0200
>> > OS Version: Mac OS X 10.9.3 (13D65)
>> > Report Version: 11
>> > Anonymous UUID: 898BFD97-214E-074A-83DA-999963349E20
>> > Sleep/Wake UUID: 074ECD49-01FF-408E-8E93-087F7A4E4776
>> > Crashed Thread: 0
>> > Exception Type: EXC_BREAKPOINT (SIGTRAP)
>> > Exception Codes: 0x0000000000000002, 0x0000000000000000
>> > Application Specific Information:
>> > dyld: launch, loading dependent libraries
>> > Dyld Error Message:
>> > Library not loaded: QtSvg.framework/Versions/4/QtSvg
>> > Referenced from:
>> /Volumes/VOLUME/QGIS_2.3-dev.app/Contents/MacOS/lib/libqwt.dylib
>> > Reason: image not found
>> > Binary Images:
>> > 0x7fff6c4d4000 - 0x7fff6c507817 dyld (239.4)
>> <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
>> > 0x7fff89306000 - 0x7fff89306fff com.apple.ApplicationServices
>> (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031>
>> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
>> > 0x7fff8caa3000 - 0x7fff8caf1ff9 libstdc++.6.dylib (60)
>> <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
>> > 0x7fff8d29c000 - 0x7fff8d481fff com.apple.CoreFoundation (6.9 -
>> 855.16) <A63E680E-E4B2-368B-8564-9DBE0D8DDB91>
>> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
>> > 0x7fff8e6e6000 - 0x7fff8e752fff com.apple.framework.IOKit
>> (2.0.1 - 907.100.13) <057FDBA3-56D6-3903-8C0B-849214BF1985>
>> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
>> > 0x7fff92c58000 - 0x7fff92c59ff7 libSystem.B.dylib (1197.1.1)
>> <E303F2F8-A8CF-3DF3-84B3-F2D0EE41CCF6> /usr/lib/libSystem.B.dylib
>> > 0x7fff930a5000 - 0x7fff930a5fff com.apple.CoreServices (59 -
>> 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5>
>> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
>> > 0x7fff93268000 - 0x7fff93280fff libexpat.1.dylib (12)
>> <97F4A9A7-CB3E-3BBF-9314-4997FC770E52> /usr/lib/libexpat.1.dylib
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140528/e3a897a0/attachment-0001.html>
