[Qgis-developer] [GRASS-dev] GRASS & QGIS: the future
Markus Neteler
neteler at osgeo.org
Fri May 30 12:33:07 PDT 2014
On Fri, May 30, 2014 at 12:38 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Radim Blazek wrote:
>> > Can you try the attached patch? The new function should be used like:
>> > if (setjmp(*G_fatal_longjmp(1))) {
>> > // this will be executed on fatal errors
>> Works. Can I hope the patch will find a way to 7.0.0?
> Committed in r60590.
> The only aspect which might be invasive is that defs/gis.h now
> includes <setjmp.h> for the jmp_buf declaration. Although this is a
> standard C header, it's not necessarily as straightforward as other
> headers, being tied to the compiler's internals. I would advise
> checking whether there are any build issues on less-common platforms
> (e.g. AIX) before promoting the change to release.
I have patched my relbr7 locally on the AIX supercomputer and it compiles.
Markus
