[Qgis-developer] Implemented break lines on intersections option during line layers editing
Tim Sutton
lists at linfiniti.com
Sat May 31 23:02:54 PDT 2014
Hi
On Fri, May 30, 2014 at 11:53 PM, G. Allegri <giohappy at gmail.com> wrote:
> I've implemented the option to break lines when a new line intersects
> existing lines on the same layer.
> I've added the option to the "snapping options" dialog. Having the "avoid
> intersections" option for polygons, I've added a new column to define the
> different meanings of the checkbox, in case it's a line layer or a polygon
> layer. See the image:
> http://cdn.img42.com/d77a446f9a52b9d0315c4b78cfce8141.png
> Is it ok to add the option over there?
Nice! Can you remove the abbreviation and change the text to say simply
"Split intersecting lines" (using 'spilt' will be more consistent with
other digitising tools and sounds less negative than break which sounds
like something gets damaged).
Regards
Tim
> giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140601/c8948081/attachment.html>
