[Qgis-developer] 2.6: first overview
James Wood
jwood911 at gmail.com
Sun Nov 2 18:50:20 PST 2014
Nic,
I upgraded to 2.6.0 x64 using the stand-alone installer for Windows (I have two machines: OS 8 and 7 SP1). I am not experiencing the attribute table editing issue that you describe. I experienced a couple of crash dump error windows on exit, but these were mostly while saving older QGIS documents to the new format that also had pathing problems to some layers. Once saved as a 2.6 doc, I have not had any crash dump errors on exit. Also, with respect to the Browse option for unhandled layers, it was greyed out for me when the referenced MSSQL spatial DB had already been deleted. Obviously, these layers were inconsequential, but it would have been easy to manually enter the new instance path had I needed to.
Love the new features and improvements with 2.6...
All the best,
James
To: qgis-developer at lists.osgeo.org
Date: Sun, 2 Nov 2014 23:11:14 +0100
Subject: [Qgis-developer] 2.6: first overview
Hi all,
just few things I'm
experiencing with 2.6:
Attribute Table: modifying the content of a cell, it needs to save and reopen the table to
see it updated...normal behaviour?
Crash:
different types. Usually c
losing the project, QGIS ends up with a
minidump or the MS error window "The software stopped to work
etc etc". This happens closing .qgs from 2.2 with or without
saving to 2.6 version. Sometimes also while working. Attached you
can find the .dmp (shall I upload them? I don't know how to deal
with). Actually it's a quite annoying issue...
Corrupt layers: the table appears but double-clicking the source it
doesn't open the explorer as in 2.2; it only allows to modify the folder
destination as text. Is that the new behavior?
Translation (ITA):
just few oversights:
color selection
panel: "incolla collore"
modify widget
properties: "il widget di modica può..."
Is there anyone with the
same issues? I'm working with W8.1 64bit and QGIS standalone.
As always: thank you all for
your work!
All the best,
Nic
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141103/e8ac41be/attachment-0001.html>
