[Qgis-developer] 2.6: first overview
    Niccolò Marchi
    sciurusurbanus at hotmail.it
    Mon Nov  3 01:59:08 PST 2014
Matthieu
actually, the project file got broken after a minidump...I don't know if it still turns useful.
sample data: which kind? the project is quite "thick"...
btw, in the meanwhile I'll try to open a ticket on it.
thank you very much!
Date: Mon, 3 Nov 2014 07:07:48 +0700
Subject: Re: [Qgis-developer] 2.6: first overview
To: sciurusurbanus at hotmail.it
CC: qgis-developer at lists.osgeo.org
Niccola,
With regards to point 1 & 2, you would increase the chance of those issues being fixed (and help QGIS) by filing tickets at hub.qgis.org . Be as descriptive as you can, provide steps to reproduce what affects you; that should be enough to get a developer to look into it. Sample data source & project file leading to issue a bonus.
M
On 3 Nov 2014 05:16, "Niccolò Marchi" <sciurusurbanus at hotmail.it> wrote:
Hi all,
just few things I'm
experiencing with 2.6:
Attribute Table: modifying the content of a cell, it needs to save and reopen the table to
	see it updated...normal behaviour?
Crash:
	different types. Usually closing the project, QGIS ends up with a
	minidump or the MS error window "The software stopped to work
	etc etc". This happens closing .qgs from 2.2 with or without
	saving to 2.6 version. Sometimes also while working. Attached you
	can find the .dmp (shall I upload them? I don't know how to deal
	with). Actually it's a quite annoying issue...
Corrupt layers: the table appears but double-clicking the source it
	doesn't open the explorer as in 2.2; it only allows to modify the folder
	destination as text. Is that the new behavior?
Translation (ITA):
	just few oversights:
color selection
		panel: "incolla collore"
modify widget
		properties: "il widget di modica può..."
Is there anyone with the
same issues? I'm working with W8.1 64bit and QGIS standalone.
As always: thank you all for
your work!
All the best,
Nic
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141103/8a1995ba/attachment-0001.html>
