[Qgis-developer] 2.6: first overview
    Giovanni Manghi
    giovanni.manghi at faunalia.pt
    Mon Nov  3 00:39:54 PST 2014
> Crash:
>         different types. Usually closing the project, QGIS ends up with a
>         minidump or the MS error window "The software stopped to work
>         etc etc". This happens closing .qgs from 2.2 with or without
>         saving to 2.6 version. Sometimes also while working. Attached you
>         can find the .dmp (shall I upload them? I don't know how to deal
>         with). Actually it's a quite annoying issue...
I have seen the crash on exit on several machines, it is usually a
plugon problem, try disable/remove your plugins, at some point you
will probably find the one is causing the crash.
cheers
