[Qgis-developer] [Qgis-tr] size of translations, use a distinct repo?
Werner Macho
werner.macho at gmail.com
Wed Nov 12 00:41:59 PST 2014
Hi Jürgen!
I am not sure what are you aiming at, but yes - we could do it that way too.
As long as QGIS does not use qgis_en.ts we could just tx pull it -
update it and tx push it back to transifex.
(And forget about it in the source tree). The same way we could do it
with all the translations.. pulling the right in front of a compile
run and forget about them afterwards and only commit them right in
front of a branching the release branch.
As I said - as long as translations can be considered to be in the
nightly build I am confident that people compiling QGIS on their own
can also pull translations before they build.
The only problem I see is when nightly is not updating translations
and people cannot see their translations (and possibly adjust it).
(This only because I sometimes got asked about updating the languages
in the source tree so that translators can see the work before it is
getting "released")
If I am getting you correct we could update the i18n directory only
once per release. Is this what you are aiming for?
kind regards
Werner
On Wed, Nov 12, 2014 at 9:31 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Werner,
> On Tue, 11. Nov 2014 at 23:24:07 +0100, Werner Macho wrote:
>> Sounds like a reasonable idea to me, if the translations will be in
>> nightly I've got no problem (and I also think that the translators
>> don't have any). For people compiling out of sources it shouldn't be
>> any problem to pull from transifex either and compile.
> If I update qgis_en.ts the usual way, there are now differences (e.g. '
> instead of '). Looks like qgis_en.ts was pulled from transifex. Is that
> necessary for anything? And how does transifex handle changes like that?
> On second thought do we need a uptodate qgis_en.ts in our repository at all?
> QGIS doesn't use it - it's only there for transifex to watch.
> Instead of updating and commiting it in the source repository (and see lots of
> otherwise useless changes) we could simply have update_ts_files.sh pull it from
> transifex, update it with the latest source changes and push it back.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iQIVAwUBVGMa+xBsJ9SQbsVUAQIbwRAAtuxd3KfMQtBWDm7kYg478kWW9baN4bEe
> oTTAst0RzohGrQy9ePN8NQdiWxOzEJih0VnSYoFr9F+6A5eZ2S6IrC6vUUpX0fh6
> 6oTqc0Cxf5GyzGhtMQA1uzLXCjXRLJkEGrylTpC1MvhVzsiRxSj7hCJdEEAzJOKt
> rybxf9Gtb7QSxAT2DNedmYPhfPpRzvcTB/JruDSjExHFxH7cH11iQpnhPv06+YVG
> 1MTQXIRuNQnMYhPj4MXqSbTzOhH/YcDfgf62k2RnKWhszzcLWIXBVz/m9Wl1gKXJ
> J0uNQYX9DKH1PbxR/HQ+GYxdX5/4NPEaM2T/mOGewWgVH0x79FX/3jFzvIhMrXJd
> 7yFFkWBlHpf8Ish0XoTaf5NbiH8Kha1DZsiXFwqh0tZOazuxRdoQC+WZ9Kg/0ESQ
> /jZe/eWP7/k7Kh9t2QOnJ7iqoqaK8hEdwHjC6MUece4CO8fmj+1SIS+xcb56ILK8
> dmP07G43mkWcnD7Dc25x6/bDB+hjCtMqkbDrBUtmpR4SJMHfJ7crIiQbiuslrHPe
> 56MFXud5dY8ykjY0Z0ELZ2XFPaenMLbAu0sUd1DbLi8vyeo8kY4oOeleuFp50Y+x
> hHy45bkc1hRlVNrHSHmZjhBJQ+sp0X/N4S7r6RlxkXsWkqx5Kly76lzMM4TVoDBk
> Tk8OTIGhSwk=
> =YvwM
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
