[Qgis-developer] Re : 2.6: first overview
Niccolò Marchi
sciurusurbanus at hotmail.it
Mon Nov 3 02:01:30 PST 2014
ok Paolo and Werner: I'll do it :)
thank you Junior and all the others for the support!
To: werner.macho at gmail.com; sciurusurbanus at hotmail.it
CC: qgis-developer at lists.osgeo.org
Subject: Re : [Qgis-developer] 2.6: first overview
Date: Mon, 3 Nov 2014 00:18:29 +0100
Hi,About corrupted layers, yes this is the new behaviour. You can now directly write the good path. But there is also a browser button at the bottom of the dialog. Select the layer in the list and click on this button will open the explorer, as old double-click behaved.
Envoyé depuis mon HTC
----- Reply message -----
De : "Werner Macho" <werner.macho at gmail.com>
Pour : "Niccolò Marchi" <sciurusurbanus at hotmail.it>
Cc : "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>
Objet : [Qgis-developer] 2.6: first overview
Date : dim., nov. 2, 2014 23:29
Hi!
Regarding translation it is now easier than ever before to contribute
and change the things yourself.
Just get an account on transifex [0] and apply for the italian
language - search for the typos and change them by yourself. That way
you make sure the correct string will find it's way into the next
release.
kind regards
Werner
[0] https://www.transifex.com/projects/p/QGIS
On Sun, Nov 2, 2014 at 11:11 PM, Niccolò Marchi
<sciurusurbanus at hotmail.it> wrote:
> Hi all,
> just few things I'm experiencing with 2.6:
> Attribute Table: modifying the content of a cell, it needs to save and
> reopen the table to see it updated...normal behaviour?
> Crash: different types. Usually closing the project, QGIS ends up with a
> minidump or the MS error window "The software stopped to work etc etc". This
> happens closing .qgs from 2.2 with or without saving to 2.6 version.
> Sometimes also while working. Attached you can find the .dmp (shall I upload
> them? I don't know how to deal with). Actually it's a quite annoying
> issue...
> Corrupt layers: the table appears but double-clicking the source it doesn't
> open the explorer as in 2.2; it only allows to modify the folder destination
> as text. Is that the new behavior?
> Translation (ITA): just few oversights:
> color selection panel: "incolla collore"
> modify widget properties: "il widget di modica può..."
> Is there anyone with the same issues? I'm working with W8.1 64bit and QGIS
> standalone.
> As always: thank you all for your work!
> All the best,
> Nic
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141103/29b5f411/attachment.html>
