[Qgis-developer] [Qgis-tr] size of translations, use a distinct repo?
Denis Rouzaud
denis.rouzaud at gmail.com
Sun Nov 2 23:32:01 PST 2014
Hi again,
Thanks again for you work Werner.
Last translation commit is quite large again, due to the Spanish file,
although from a quick look it just seems to be new translations...
Anyway, I'd like to raise again the idea of using git submodule for
translation files.
As written before, I think they are quite useless in the main repo. Even
if we can limit drastically the growth of the files, I think they would
be better suited in a distinct repo and have a small advantage regarding
growth of the main repo.
I found a project [0] which is using github / transifex with git
submodule for translation files [1].
I believe no changes to current translation scripts would be required
thanks to git submodules.
It would just be a question of initialising the submodule and changing
the url wherever needed.
Does this need a QEP ? ;)
Best wishes,
Denis
[0]
http://www.ushahidi.com/2012/08/21/localization-and-translation-with-transifex/
[1] https://github.com/ushahidi/Ushahidi_Web/tree/develop/application
On 30.10.2014 17:12, Werner Macho wrote:
> Hi!
> I am sorry for not realizing that :(
> But from now on it should be much better ..
> Other thing is that I think about only updating all translations in
> source only every two weeks (or probably only in front of a release)
> as the translation should be done in transifex anyway. And only
> updating the english source in transifex (and master of course).
> Pros: even smaller and less commits,
> Cons: Some translators often like to see "how it looks like" and I
> understand that from time to time you want to see if "it fits".
> What do you think about that?
> regards
> Werner
> On Thu, Oct 30, 2014 at 4:28 PM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> Hi Werner,
>> Thanks for this, indeed last translation commit is indeed much smaller!!!!
>> Less than 1k lines while it used to be about 50k before.
>> Cheers,
>> Denis
>> On 29.10.2014 20:49, Werner Macho wrote:
>>> Hi!
>>> I added the suggestion from jef and tried the new produced ts files in
>>> linguist and transifex without any problems ..
>>> So I decided to update everything again (with strings and transifex
>>> update) ..
>>> ts files should now have no location inside any more ..
>>> I hope that shrinks down the size from now on.
>>> regards
>>> Werner
>>> On Wed, Oct 29, 2014 at 2:56 PM, Stott, James <fmrojst at fylkesmannen.no>
>>> wrote:
>>>> As a slight side point, according to transifex it looks like we could
>>>> have 13 fully translated languages for the GUI by the time 2.6 is released
>>>> (13 languages are on 99% or more). 15 languages are over 95%. This is
>>>> excellent news.
>>>> Is it something we should publise, maybe add to the visual changelog?
>>>> -----Opprinnelig melding-----
>>>> Fra: qgis-tr-bounces at lists.osgeo.org
>>>> [mailto:qgis-tr-bounces at lists.osgeo.org] På vegne av Werner Macho
>>>> Sendt: 29. oktober 2014 14:15
>>>> Til: Denis Rouzaud
>>>> Kopi: QGIS Translation Discussions; qgis-developer
>>>> Emne: Re: [Qgis-tr] [Qgis-developer] size of translations, use a distinct
>>>> repo?
>>>> hmm - ok ..
>>>> Then I am going to give it a try without location and see if there are
>>>> any problems with transifex or linguist ..
>>>> If not - I also think that way is perfect ..
>>>> regards
>>>> Werner
>>>> On Wed, Oct 29, 2014 at 2:11 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
>>>> wrote:
>>>>> On 29.10.2014 14:06, Werner Macho wrote:
>>>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>>> Hash: SHA1
>>>>>> Good idea,
>>>>>> if its really translation that causes the growth we should do
>>>>>> everything to avoid that.
>>>>> As Jurgen noticed, there are some useless changes in the ts files:
>>>>> <message>
>>>>> - <location filename="../src/core/qgscontexthelp_texts.cpp"
>>>>> line="327"/>
>>>>> + <location filename="../src/core/qgscontexthelp_texts.cpp"
>>>>> line="319"/>
>>>>> if there are lines removed/added in the source file, this will cause
>>>>> changes in the translation file.
>>>>> Jurgen suggested to remove these tags "location filename" which would
>>>>> improve a lot.
>>>>>> Is there any way to "shrink" the already existing repo?
>>>>>> At one point I thought about zipping the ts files - but if there is a
>>>>>> better way .. good!
>>>>>> I always wondered why the whole translations file has to be changed
>>>>>> whenever there are only some small changes ..
>>>>>> moving the translation in it's own github repository: hmm - I don't
>>>>>> know if thats easily possible.. but I am also willing to try it if it
>>>>>> helps the source code to stay clean.
>>>>> I don't see any reason why it wouldn't be possible.
>>>>> git submodules would be pretty useful for this matter.
>>>>>> But again - anyway to shrink the already existing source code?
>>>>> As far as I know, you can't shrink existing repo without destroying
>>>>> the history.
>>>>>> I don't mind about loosing track of translation changes.
>>>>>> regards
>>>>>> Werner
>>>>>> On 10/29/2014 12:15 PM, Jürgen E. Fischer wrote:
>>>>>>> Hi Denis,
>>>>>>> On Wed, 29. Oct 2014 at 11:08:16 +0100, Denis Rouzaud wrote:
>>>>>>>> Any thoughts?
>>>>>>> I guess this is just due to the "location filename" stuff. That
>>>>>>> often causes massive change in the ts files, because lines were
>>>>>>> added or removed from the source files - even if there isn't even a
>>>>>>> changed translation.
>>>>>>> I think that is not used at all for transifex and it's not that
>>>>>>> important to have in linguist either.
>>>>>>> So instead of inventing something new, all it takes might be to add
>>>>>>> "-locations none" to our lupdate call, reduce the size of the .ts
>>>>>>> files a lot (in one huge commit) and avoid useless tracking of
>>>>>>> location changes in the future.
>>>>>>> Objections?
>>>>>>> Jürgen
>>>>>>> _______________________________________________ Qgis-tr mailing list
>>>>>>> Qgis-tr at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
>>>>>> -----BEGIN PGP SIGNATURE-----
>>>>>> Version: GnuPG v1.4.15 (GNU/Linux)
>>>>>> iEYEARECAAYFAlRQ5k8ACgkQDAH1YiCxBgn7TQCeKllHCgzKm1Jn2iRT6iwPXkPd
>>>>>> qmsAnjjWeXZySoZX9WQYf82w4s64s2ql
>>>>>> =AGCZ
>>>>>> -----END PGP SIGNATURE-----
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
