[Qgis-developer] [Qgis-tr] size of translations, use a distinct repo?
Nyall Dawson
nyall.dawson at gmail.com
Sun Nov 2 23:36:00 PST 2014
On 03/11/2014 6:32 pm, "Denis Rouzaud" <denis.rouzaud at gmail.com> wrote:
> Hi again,
> Thanks again for you work Werner.
> Last translation commit is quite large again, due to the Spanish file,
although from a quick look it just seems to be new translations...
> Anyway, I'd like to raise again the idea of using git submodule for
translation files.
Would this also help us fine tune commit permissions on both repos? I'd
imagine that there's a lot of non developers who could potentially benefit
from commit rights for translations?
> As written before, I think they are quite useless in the main repo. Even
if we can limit drastically the growth of the files, I think they would be
better suited in a distinct repo and have a small advantage regarding
growth of the main repo.
+1
Nyall
> I found a project [0] which is using github / transifex with git
submodule for translation files [1].
> I believe no changes to current translation scripts would be required
thanks to git submodules.
> It would just be a question of initialising the submodule and changing
the url wherever needed.
> Does this need a QEP ? ;)
> Best wishes,
> Denis
> [0]
http://www.ushahidi.com/2012/08/21/localization-and-translation-with-transifex/
> [1] https://github.com/ushahidi/Ushahidi_Web/tree/develop/application
> On 30.10.2014 17:12, Werner Macho wrote:
>> Hi!
>> I am sorry for not realizing that :(
>> But from now on it should be much better ..
>> Other thing is that I think about only updating all translations in
>> source only every two weeks (or probably only in front of a release)
>> as the translation should be done in transifex anyway. And only
>> updating the english source in transifex (and master of course).
>> Pros: even smaller and less commits,
>> Cons: Some translators often like to see "how it looks like" and I
>> understand that from time to time you want to see if "it fits".
>> What do you think about that?
>> regards
>> Werner
>> On Thu, Oct 30, 2014 at 4:28 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
>>> Hi Werner,
>>> Thanks for this, indeed last translation commit is indeed much
smaller!!!!
>>> Less than 1k lines while it used to be about 50k before.
>>> Cheers,
>>> Denis
>>> On 29.10.2014 20:49, Werner Macho wrote:
>>>> Hi!
>>>> I added the suggestion from jef and tried the new produced ts files in
>>>> linguist and transifex without any problems ..
>>>> So I decided to update everything again (with strings and transifex
>>>> update) ..
>>>> ts files should now have no location inside any more ..
>>>> I hope that shrinks down the size from now on.
>>>> regards
>>>> Werner
>>>> On Wed, Oct 29, 2014 at 2:56 PM, Stott, James <fmrojst at fylkesmannen.no>
>>>> wrote:
>>>>> As a slight side point, according to transifex it looks like we could
>>>>> have 13 fully translated languages for the GUI by the time 2.6 is
released
>>>>> (13 languages are on 99% or more). 15 languages are over 95%. This is
>>>>> excellent news.
>>>>> Is it something we should publise, maybe add to the visual changelog?
>>>>> -----Opprinnelig melding-----
>>>>> Fra: qgis-tr-bounces at lists.osgeo.org
>>>>> [mailto:qgis-tr-bounces at lists.osgeo.org] På vegne av Werner Macho
>>>>> Sendt: 29. oktober 2014 14:15
>>>>> Til: Denis Rouzaud
>>>>> Kopi: QGIS Translation Discussions; qgis-developer
>>>>> Emne: Re: [Qgis-tr] [Qgis-developer] size of translations, use a
distinct
>>>>> repo?
>>>>> hmm - ok ..
>>>>> Then I am going to give it a try without location and see if there are
>>>>> any problems with transifex or linguist ..
>>>>> If not - I also think that way is perfect ..
>>>>> regards
>>>>> Werner
>>>>> On Wed, Oct 29, 2014 at 2:11 PM, Denis Rouzaud <
>>>>> wrote:
>>>>>> On 29.10.2014 14:06, Werner Macho wrote:
>>>>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>>>> Hash: SHA1
>>>>>>> Good idea,
>>>>>>> if its really translation that causes the growth we should do
>>>>>>> everything to avoid that.
>>>>>> As Jurgen noticed, there are some useless changes in the ts files:
>>>>>> <message>
>>>>>> - <location filename="../src/core/qgscontexthelp_texts.cpp"
>>>>>> line="327"/>
>>>>>> + <location filename="../src/core/qgscontexthelp_texts.cpp"
>>>>>> line="319"/>
>>>>>> if there are lines removed/added in the source file, this will cause
>>>>>> changes in the translation file.
>>>>>> Jurgen suggested to remove these tags "location filename" which would
>>>>>> improve a lot.
>>>>>>> Is there any way to "shrink" the already existing repo?
>>>>>>> At one point I thought about zipping the ts files - but if there is
a
>>>>>>> better way .. good!
>>>>>>> I always wondered why the whole translations file has to be changed
>>>>>>> whenever there are only some small changes ..
>>>>>>> moving the translation in it's own github repository: hmm - I don't
>>>>>>> know if thats easily possible.. but I am also willing to try it if
it
>>>>>>> helps the source code to stay clean.
>>>>>> I don't see any reason why it wouldn't be possible.
>>>>>> git submodules would be pretty useful for this matter.
>>>>>>> But again - anyway to shrink the already existing source code?
>>>>>> As far as I know, you can't shrink existing repo without destroying
>>>>>> the history.
>>>>>>> I don't mind about loosing track of translation changes.
>>>>>>> regards
>>>>>>> Werner
>>>>>>> On 10/29/2014 12:15 PM, Jürgen E. Fischer wrote:
>>>>>>>> Hi Denis,
>>>>>>>> On Wed, 29. Oct 2014 at 11:08:16 +0100, Denis Rouzaud wrote:
>>>>>>>>> Any thoughts?
>>>>>>>> I guess this is just due to the "location filename" stuff. That
>>>>>>>> often causes massive change in the ts files, because lines were
>>>>>>>> added or removed from the source files - even if there isn't even a
>>>>>>>> changed translation.
>>>>>>>> I think that is not used at all for transifex and it's not that
>>>>>>>> important to have in linguist either.
>>>>>>>> So instead of inventing something new, all it takes might be to add
>>>>>>>> "-locations none" to our lupdate call, reduce the size of the .ts
>>>>>>>> files a lot (in one huge commit) and avoid useless tracking of
>>>>>>>> location changes in the future.
>>>>>>>> Objections?
>>>>>>>> Jürgen
>>>>>>>> _______________________________________________ Qgis-tr mailing
list
>>>>>>>> Qgis-tr at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
>>>>>>> -----BEGIN PGP SIGNATURE-----
>>>>>>> Version: GnuPG v1.4.15 (GNU/Linux)
>>>>>>> iEYEARECAAYFAlRQ5k8ACgkQDAH1YiCxBgn7TQCeKllHCgzKm1Jn2iRT6iwPXkPd
>>>>>>> qmsAnjjWeXZySoZX9WQYf82w4s64s2ql
>>>>>>> =AGCZ
>>>>>>> -----END PGP SIGNATURE-----
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Qgis-tr mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141103/08813679/attachment-0001.html>
