[Qgis-developer] QGIS web client not displaying full WMS extent
Andreas Neumann
a.neumann at carto.net
Wed Nov 5 04:27:30 PST 2014
Hi Stefan,
Unfortunately I don't have the time to look further into the issue. Did
you have a look at the WMS requests that QGIS is creating? Maybe this
helps a bit.
I am fortunate enough to work in just one projection system ...
Andreas
On 04.11.2014 22:48, Blumentrath, Stefan wrote:
> Hi Andreas,
> Thanks for your reply, and sorry for the confusion. It is indeed a
> "QGIS as a WMS client" issue.
> I now tested with different CRS which the WMS uses,
> namely EPSG:25833,32633,and 4326.
> I added one layer for each CRS and then stepwise changed my project CRS.
> With my QGIS project in WGS84 all data of the layer WGS84 layer is
> displayed properly (however in a form which is little suitable for map
> production), while EPSG:25833 layer only showed the lower left quarter
> of the map and 32633 had the "clipped" data extent mentioned.
> Then I switched to EPSG:25833. Here for the WGS84 layer and the
> EPSG:25833 layer only the lower left quarter of the map is visible,
> and the EPSG:32633 layer had again the clipped extent. Zoom-to-layer
> on the EPSG:25833 resulted in a 1:35Mio scale while zoom-to-layer on
> the EPSG:32633 layer resulted in a 1:10Mio scale...
> Switching the project to 32633 gave the same result as the project in
> 25833.
> Here I also noticed that on-the-fly projection was activated when
> switchen forth and back between layers...
> So, it seems indeed somehow related to CRS, do you have a second or
> third thing you would check?
> Does the server send different data for different CRS? Or is it
> something else?
> Cheers
> Stefan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141105/334ebe89/attachment.html>
