[Qgis-developer] Batch generation of map images with MTR
Andreas Neumann
a.neumann at carto.net
Wed Nov 5 23:26:13 PST 2014
Hi Richard,
You may also want to have a look at the Atlas serial printing. It is
getting more and more powerful with each QGIS release.
Maybe it does what you need?
Andreas
On 06.11.2014 00:02, Nathan Woodrow wrote:
> Hey Richard,
> There is a new class you can use for the rendering because we now have
> MTR you have to wait for the image, or listen for the done event. The
> code is pretty easy and you can see an example of me using it here:
> https://github.com/DMS-Aus/qgis2img/blob/master/qgis2img/render.py#L43
> The basics are:
> job = QgsMapRendererParallelJob(settings)
> job.start()
> job.waitForFinished()
> image = job.renderedImage()
> settings is a QgsMapSettings class which you can make or take from the
> canvas using iface.mapCanvas().mapSetttings()
> QgsMapSettings has a list of layers to render so you can update that
> without changing the layers on the canvas, it's very handy.
> Give that a try and see how you go.
> - Nathan
> On Thu Nov 06 2014 at 1:30:54 AM Richard Burkmar
> <rich.burkmar at gmail.com <mailto:rich.burkmar at gmail.com>> wrote:
> My apologies - I didn't check the latest version of MMQGIS so my
> statement that the animation feature doesn't work with the latest
> version of QGIS was incorrect. It seems that they have solved the
> problem that I encountered, so I'll take a look at the code there.
> (I hope that this message comes out in the correct thread - I
> couldn't see how to do it, so I'm sending a message with the same
> title. I'm new to these mailing lists.)
> Rich
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141106/c1f291ab/attachment.html>
