[Qgis-developer] Batch generation of map images with MTR
Richard Burkmar
rich.burkmar at gmail.com
Thu Nov 6 01:44:12 PST 2014
Many thanks for all the help. Before I got the responses, I found a way to
make it work, but I'm clearly not working with the new paradigm, so I will
revisit it soon. That code looks very neat Nathan. Thanks for the tip about
Atlas Andreas - I will look at that too.
Thanks and best wishes,
Rich
On Wed, Nov 5, 2014 at 11:02 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Richard,
> There is a new class you can use for the rendering because we now have MTR
> you have to wait for the image, or listen for the done event. The code is
> pretty easy and you can see an example of me using it here:
> https://github.com/DMS-Aus/qgis2img/blob/master/qgis2img/render.py#L43
> The basics are:
> job = QgsMapRendererParallelJob(settings)
> job.start()
> job.waitForFinished()
> image = job.renderedImage()
> settings is a QgsMapSettings class which you can make or take from the
> canvas using iface.mapCanvas().mapSetttings()
> QgsMapSettings has a list of layers to render so you can update that
> without changing the layers on the canvas, it's very handy.
> Give that a try and see how you go.
> - Nathan
> On Thu Nov 06 2014 at 1:30:54 AM Richard Burkmar <rich.burkmar at gmail.com>
> wrote:
>> My apologies - I didn't check the latest version of MMQGIS so my
>> statement that the animation feature doesn't work with the latest version
>> of QGIS was incorrect. It seems that they have solved the problem that I
>> encountered, so I'll take a look at the code there.
>> (I hope that this message comes out in the correct thread - I couldn't
>> see how to do it, so I'm sending a message with the same title. I'm new to
>> these mailing lists.)
>> Rich
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141106/6b742ae5/attachment.html>
