[Qgis-developer] MTR and Postgis - lots of crashes
Andreas Neumann a.neumann at carto.net
Thu Nov 6 02:01:11 PST 2014
Hi Denis,
Thanks for the hint.
I had a check on the nr of open connections on our PostgreSQL server.
The results of
SELECT sum(numbackends) FROM pg_stat_database;
are always in the 20ies.
I allow 100 connections on the PostgreSQL server. So this does not
explain the problems.
The crashes always happen directly after project load. Once its loaded
without a crash I never have subsequent crashes.
So something critical seems to happen on project load.
Andreas
On 06.11.2014 10:48, Denis Rouzaud wrote:
> On 06.11.2014 10:43, Andreas Neumann wrote:
>> Hi,
>> Am I the only one that still gets a lot of crashes with complex
>> projects when the data sources are on Postgis and MTR (parallel
>> rendering in multiple cores) is turned on? I get most crashes on
>> Windows, hardly any on Linux, but this may be due to the fact that
>> Linux accesses Postgis locally, whereas the Win QGIS clients access
>> Postgis remotely. Turning off MTR --> no more crashes.
>> Is MTR and Postgis working flawlessly for everyone?
>> These crashes really annoy me and I have to turn off MTR until these
>> problems are fixed.
>> Thank you for any hints / sharing your experiences with Postgis and MTR.
> I experienced freezes with MTR when I used joined attributes for
> symbology/labelling. The joins being not cached.
> My interpretation was that the number of allowed connections to
> postgres reached its maximum, and hence no connection is available to
> fetch the layers used for labeling/symbology.
> Caching all my joins saved the problem on my side.
> I don't experience any trouble either on win or linux, and I suppose I
> can say I have complex projects ;)
> Denis
