[Qgis-developer] Fwd: Question re: rotating an SVG
Alexandre Neto senhor.neto at gmail.com
Thu Nov 6 12:38:32 PST 2014
Have you connected the svg image to your map? Since you can have more than
one map in the same composition,  you need to select the map that will
control the image rotation.
Best regards,
Alexandre
Em 06/11/2014 18:56, "Jesse McGraw" <jlmcgraw at gmail.com> escreveu:
> I'm attempting to use an SVG image of a compass rose as a background
> element that is rotated by a data defined number of degrees.
> Currently, when the image is rotated, the numbers on the outside of the
> ring are not rotating as expected along with the rest of the image (I want
> to rotate the image as a whole).
> I thought perhaps QGIS might be rotating each object within the SVG
> independently but that doesn't seem to be the case either
> Am I doing something wrong or is this an issue with the SVG or perhaps
> QGIS' SVG rendering?
> I've included links to the SVG itself as well as a screenshot of what it
> currently looks like in QGIS and what I'd expect it to look like (as done
> manually in Inkscape).
> SVG
> https://drive.google.com/file/d/0B4EbUsrclSoDU0hqWWdsVlBjcGM/view?usp=sharing
> QGIS rotated image
> https://drive.google.com/file/d/0B4EbUsrclSoDWjhTSFJtM0FkRVU/view?usp=sharing
> Inkscape rotated image
> https://drive.google.com/file/d/0B4EbUsrclSoDdFlRQ2o2cVF1N0E/view?usp=sharing
> Relevant QGIS info (running under Xubuntu linux x64 13.10)
> QGIS version    2.6.0-Brighton
> QGIS code revision    exported
> Compiled against Qt    4.8.6
> Running against Qt    4.8.6
> Compiled against GDAL/OGR    1.10.1
> Running against GDAL/OGR    1.10.1
> Compiled against GEOS    3.4.2-CAPI-1.8.2
> Running against GEOS    3.4.2-CAPI-1.8.2 r3921
> PostgreSQL Client Version    9.3.4
> SpatiaLite Version    4.1.1
> QWT Version    5.2.3
> PROJ.4 Version    480
> QScintilla2 Version    2.8.1
> Thanks,
>   Jesse
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141106/aa4e89c2/attachment.html>
