[Qgis-developer] transition to QT5... QT4 removed will be removed from Debian Jessie
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Nov 7 00:20:27 PST 2014
Hi Werner
https://github.com/m-kuhn/QGIS/tree/final-2_4_0-qt5
You may need to revert
9c6f1698fcb3
Make sure that dependencies are also compiled and linked against Qt5
(QWT/QWTPolar being the most prominent ones).
Start in an empty build directory
run `cmake -DENABLE_QT5=TRUE -DWITH_BINDINGS=FALSE`
Matthias
On 11/07/2014 09:15 AM, Werner Macho wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> which branch do I have to checkout to test a qt5 compile run?
> regards
> Werner
> On 11/07/2014 09:13 AM, Richard Duivenvoorde wrote:
>> On 06-11-14 10:41, Matthias Kuhn wrote:
>>> On 06.11.2014 10:33, Matthias Kuhn wrote:
>>>>> could the migration have an impact on plugins?
>>>> Yes, some classes are no longer supported but the delta is
>>>> small
>>> The biggest problem will probably be old-style signal/slot
>>> connections. Maybe we should encourage people to use new-style
>>> connections to be prepared.
>> This, and an easy way to install a QT5-QGIS version, so plugin devs
>> who are not able to compile can 'just install QT5-QGIS and just
>> test their plugin?
>> Regards,
>> Richard
>> _______________________________________________ Qgis-developer
>> mailing list Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.15 (GNU/Linux)
> iEYEARECAAYFAlRcf44ACgkQDAH1YiCxBgkP/ACfWymWy+EZrnPm+4c6BQOMh8Nt
> VcEAn2jaWOo21CLKQkEEogE6ixis0IxJ
> =AxM7
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
Please help taking QGIS to the next level of quality. Before November 15 !
http://blog.vitu.ch/10102014-1046/crowdfunding-initiative-automated-testing
