[Qgis-developer] transition to QT5... QT4 removed will be removed from Debian Jessie
Werner Macho
werner.macho at gmail.com
Fri Nov 7 00:37:21 PST 2014
hmm
obviously Qt5.3 is minimum for compiling .. because it is searching
for a qtpositioning here and as I only have Qt5.1.1 available here I
am out of testing it :)
waiting for the distribution update *gg*
thanks for the info anyway ..
regards
Werner
On Fri, Nov 7, 2014 at 9:20 AM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Hi Werner
> https://github.com/m-kuhn/QGIS/tree/final-2_4_0-qt5
> You may need to revert
> 9c6f1698fcb3
> Make sure that dependencies are also compiled and linked against Qt5
> (QWT/QWTPolar being the most prominent ones).
> Start in an empty build directory
> run `cmake -DENABLE_QT5=TRUE -DWITH_BINDINGS=FALSE`
> Matthias
> On 11/07/2014 09:15 AM, Werner Macho wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> which branch do I have to checkout to test a qt5 compile run?
>> regards
>> Werner
>> On 11/07/2014 09:13 AM, Richard Duivenvoorde wrote:
>>> On 06-11-14 10:41, Matthias Kuhn wrote:
>>>> On 06.11.2014 10:33, Matthias Kuhn wrote:
>>>>>> could the migration have an impact on plugins?
>>>>> Yes, some classes are no longer supported but the delta is
>>>>> small
>>>> The biggest problem will probably be old-style signal/slot
>>>> connections. Maybe we should encourage people to use new-style
>>>> connections to be prepared.
>>> This, and an easy way to install a QT5-QGIS version, so plugin devs
>>> who are not able to compile can 'just install QT5-QGIS and just
>>> test their plugin?
>>> Regards,
>>> Richard
>>> _______________________________________________ Qgis-developer
>>> mailing list Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.15 (GNU/Linux)
>> iEYEARECAAYFAlRcf44ACgkQDAH1YiCxBgkP/ACfWymWy+EZrnPm+4c6BQOMh8Nt
>> VcEAn2jaWOo21CLKQkEEogE6ixis0IxJ
>> =AxM7
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
> Please help taking QGIS to the next level of quality. Before November 15 !
> http://blog.vitu.ch/10102014-1046/crowdfunding-initiative-automated-testing
