[Qgis-developer] transition to QT5... QT4 removed will be removed from Debian Jessie
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Nov 7 02:25:53 PST 2014
I just created a pull request for Qt5.
There is no QtPositioning in there, so you may try again if you like so :)
Anybody is kindly invited to test, review and comment.
Thank you
On 11/07/2014 09:37 AM, Werner Macho wrote:
> hmm
> obviously Qt5.3 is minimum for compiling .. because it is searching
> for a qtpositioning here and as I only have Qt5.1.1 available here I
> am out of testing it :)
> waiting for the distribution update *gg*
> thanks for the info anyway ..
> regards
> Werner
> On Fri, Nov 7, 2014 at 9:20 AM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
>> Hi Werner
>> https://github.com/m-kuhn/QGIS/tree/final-2_4_0-qt5
>> You may need to revert
>> 9c6f1698fcb3
>> Make sure that dependencies are also compiled and linked against Qt5
>> (QWT/QWTPolar being the most prominent ones).
>> Start in an empty build directory
>> run `cmake -DENABLE_QT5=TRUE -DWITH_BINDINGS=FALSE`
>> Matthias
>> On 11/07/2014 09:15 AM, Werner Macho wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> which branch do I have to checkout to test a qt5 compile run?
>>> regards
>>> Werner
>>> On 11/07/2014 09:13 AM, Richard Duivenvoorde wrote:
>>>> On 06-11-14 10:41, Matthias Kuhn wrote:
>>>>> On 06.11.2014 10:33, Matthias Kuhn wrote:
>>>>>>> could the migration have an impact on plugins?
>>>>>> Yes, some classes are no longer supported but the delta is
>>>>>> small
>>>>> The biggest problem will probably be old-style signal/slot
>>>>> connections. Maybe we should encourage people to use new-style
>>>>> connections to be prepared.
>>>> This, and an easy way to install a QT5-QGIS version, so plugin devs
>>>> who are not able to compile can 'just install QT5-QGIS and just
>>>> test their plugin?
>>>> Regards,
>>>> Richard
>>>> _______________________________________________ Qgis-developer
>>>> mailing list Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.15 (GNU/Linux)
>>> iEYEARECAAYFAlRcf44ACgkQDAH1YiCxBgkP/ACfWymWy+EZrnPm+4c6BQOMh8Nt
>>> VcEAn2jaWOo21CLKQkEEogE6ixis0IxJ
>>> =AxM7
>>> -----END PGP SIGNATURE-----
>>> Qgis-developer mailing list
>> Please help taking QGIS to the next level of quality. Before November 15 !
>> http://blog.vitu.ch/10102014-1046/crowdfunding-initiative-automated-testing
